Cruise control on my road runner #1828791
05/17/15 09:49 PM
05/17/15 09:49 PM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
Hey people i am having an issue of my leg hurting and cramping really badly when driving the road runner for anymore then a say a 1/2 hour straight.
I think if i had cruise control that would help the issue as i could take my foot off the pedal on long trips. My other vehicles i drive don't give me any problems as they all have cruise control.
Anyone ever done that to an older car if so who sells a kit for it??
Thank you for your time.
Stu
Re: Cruise control on my road runner [Re: MidPenMopar] #1828807
05/17/15 10:16 PM
05/17/15 10:16 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Rostra is the only name that comes to mind for me.
http://www.rostra.com/
Don't be the exception.
Re: Cruise control on my road runner [Re: MidPenMopar] #1828905
05/18/15 12:37 AM
05/18/15 12:37 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I grabbed two complete cruise setups off cars in the junkyard. Look for aspen/volare/diplomat/5th ave. Many of them had it. I haven't tried them out yet, but they're simple cruise units. Vacuum can has in/out for the speedo cables and only a few wires to hook up. Installation looks like it will be simple and straightforward.
Re: Cruise control on my road runner [Re: DaytonaTurbo] #1829034
05/18/15 11:05 AM
05/18/15 11:05 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I use to have a issue with that. I had too much spring on my carb.
Re: Cruise control on my road runner [Re: MidPenMopar] #1829040
05/18/15 11:22 AM
05/18/15 11:22 AM
Maryland
gofastboater Offline
Maryland
I have a couple of those units around. If your interested let me know. Email me directly at rapidcapt@hotmail.com.
Re: Cruise control on my road runner [Re: mopars4ever] #1829046
05/18/15 11:28 AM
05/18/15 11:28 AM
Yes, i am going to try to reduce the spring tension on the throttle if i can first but i think it's still not going to help that much.
Re: Cruise control on my road runner [Re: Supercuda] #1829640
05/18/15 11:00 PM
05/18/15 11:00 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
I just installed a cruse control on my 69 Bee. I used the Dakota Digital cruse, which is actually a Rostra. Easy to install and works great.
Re: Cruise control on my road runner [Re: Dabee] #1829665
05/18/15 11:14 PM
05/18/15 11:14 PM
I found the link for it, but since i have the 4L60E trans which one is best?
Thank you!!
http://www.dakotadigital.com/index.cfm/page/ptype=results/category_id=477/mode=cat/cat477.htm
Re: Cruise control on my road runner [Re: MidPenMopar] #1830241
05/19/15 07:08 PM
05/19/15 07:08 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Trans type should make no diff. The cruse connects to the throtte linkage.
Re: Cruise control on my road runner [Re: Dabee] #1830242
05/19/15 07:12 PM
05/19/15 07:12 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Speed sensing is trans dependent with the kit his looking at.
Re: Cruise control on my road runner [Re: Supercuda] #1830261
05/19/15 07:47 PM
05/19/15 07:47 PM
That's actually a good thing in my case as i can hook it up to the GM overdirve i have.
Re: Cruise control on my road runner [Re: MidPenMopar] #1830278
05/19/15 08:09 PM
05/19/15 08:09 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yes, point is though, it's trans type dependent.
Re: Cruise control on my road runner [Re: Supercuda] #1830397
05/19/15 11:01 PM
05/19/15 11:01 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
JC Whitney used to have one that worked off a sensor on the driveshaft...
'63 Dodge 330
11.19 @ 121 mph
Re: Cruise control on my road runner [Re: Supercuda] #1830442
05/19/15 11:46 PM
05/19/15 11:46 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
All he needs to do is order the kit for his trans type. The only diff in the kit is the type of speed sensor used. I've installed several of these things using electronic speed signal from the ECU and cable driven signals using the kit supplied speed sensor.
If installing on any vehicle that does not have an electronic Vehicle Speed Sender (VSS) or does not have a GM- type speedometer cable please order the CRS-3000-4165. The CRS-3000-4165 kit includes a magnetic drive shaft senders where magnets SEN-4165 are attached to the drive shaft to create a speed signal.
Re: Cruise control on my road runner [Re: Dabee] #1830496
05/20/15 12:30 AM
05/20/15 12:30 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Try replying to the post in question. What trans does he have?
Re: Cruise control on my road runner [Re: Supercuda] #1830524
05/20/15 01:08 AM
05/20/15 01:08 AM
I have the 4L60E GM transmission.
Re: Cruise control on my road runner [Re: MidPenMopar] #1830658
05/20/15 10:55 AM
05/20/15 10:55 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yes, I was following along. The E means electronic control, bet you have a VSS? Which pretty much tells you which kit to pick.
Never much cared for the magnets on the drive shaft setup, what happens when the zip tie fails, and it will.
