electrical help #1828672
05/17/15 06:38 PM
05/17/15 06:38 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
current situation...electronic ignition,ballast resistor,fire wall regulator..stock 60 amp alternator...Dash voltage meter bypassed by aftermarket amp meter....everthing works fine.
installed chevy 1 wire alternator(100amp) and connected black heavy wire and nothing else.
amp gauge now reads slightly on negitive side of zero and battery reads 12 volts when running.(outside meter reads 12 volts as volt meter disabled,see 1st paragraph)
Do I need to disconnect the firewall regulator ?
What do I do with the two wires going to it ?
Thanks in advance...thanks moparts
Re: electrical help [Re: terzmo] #1828771
05/17/15 09:28 PM
05/17/15 09:28 PM
N
NITROUSN Offline
NITROUSN  Offline
N
As long as there is battery power at the alternator stud it sounds like your new one wire alternator is not working.
Re: electrical help [Re: NITROUSN] #1828872
05/17/15 11:46 PM
05/17/15 11:46 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
battery power at stud under what conditions?? key on...no key on..I have no battery power at the stud at any time
Re: electrical help [Re: terzmo] #1828890
05/18/15 12:07 AM
05/18/15 12:07 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Well there is your problem. It should be hot all the time. If your other alternator worked as you claim you must of burned up a fuse link with some sort of short to ground. Either the alternator is shorted or you accidentally grounded out that circuit.
Re: electrical help [Re: terzmo] #1829428
05/18/15 07:12 PM
05/18/15 07:12 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
found the problem...just installed the hemi after the engine bay being painted and a wire(hot) was shorting out and dropping the voltage to the alternator...fixed and now have battery power at the alternator
Thanks to all
