Re: 67 Valiant budget built to race 2015
[Re: Tomswheels]
#1828210
05/17/15 01:25 AM
05/17/15 01:25 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Tom if we were closer I would loan you my 1.18" bars and my Hellwig 7/8" rear bar in that order. I cant wait to get my combo on the road, have a bunch of little stuff to do yet. But back to your axle movement, I think some rear sliders would make a big difference. They take the shackle flex out of the equation.
Mopar to the bone!!!
[Re: amxautox]
#1828880
05/17/15 11:57 PM
05/17/15 11:57 PM
Posts: 240 Plano, Texas
68cuda440
Plano, Texas
I have a panhard bar on my AMX. Works great. Doesn't upset anything, some people have said that it would on a leaf spring car. I think it will dictate the rear roll center which will affect how the car behaves on some level, but yes, it should not affect roll rate. I am considering a Watts on my car, it will allow me to run more tire without rubbing the fender. As for bigger than a '73 bar, you can step up to running a tubular 1.5" bar with adjustable arms, that will require some fabrication to mount up. If you do a 2" tube with bushings to mount it, then want to go to a larger or smaller bar later you can use the same mount, just change the ID of the bushings to match. Not sure what bar that would dictate on the rear. I imagine to get what I want I will probably have to make it anyway. I will start out with a 1-1/8" '73 style bar on my car on the front and no bar on the rear and see how it does, then go from there.
Michael
1968 Barracuda Notchback Coupe
440 EFI 6-pack, T56 Magnum 6-spd
[Re: Tomswheels]
#1829256
05/18/15 03:47 PM
05/18/15 03:47 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Nice results Tom ... congrats and keep getting faster!!!
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Tomswheels]
#1829527
05/18/15 09:37 PM
05/18/15 09:37 PM
Posts: 380 Escondido CA USA
Tomswheels
Escondido CA USA
Thanks Mitch and everybody else, I'm going to keep researching ways to stiffen this thing up a bit. It could be worse, I found this old Barracuda pic... I do like the Panhard idea, just have to see what I can find/make work. Next race May 31!
[Re: Tomswheels]
#1831209
05/20/15 11:55 PM
05/20/15 11:55 PM
Posts: 37 Sacramento
norcal-fjo
Sacramento
Hi Tom. Congratulations on your performance so far! Looking great. I have been running the Dart in CAM-T, and I am leading the points right now in the Sacramento chapter. Before we get too excited, note that there are only seven cars in the class so far, and one got no points (non spec tires I think)so no big deal, but good so far. As far as your rear side movement, it may be less than the pictures seem, but it it does promote oversteer on quick transitions, so you might visit the "tightening" idea. The problem I have found with the 73 style front sway bar is; none of the bars I have looked at, install at anything over 50%. They all seem to tie in to the std sway bar tabs, and that's no good. My bar is installed at 70%, and I wanted to try to improve that! It will take a VERY large bar to achieve the roll rate you want at 50%. I want to change to the 73 crossmember also, but it looks like I may have to go to a custom "race type" bar. (3 pc design). Take care, and thanks for making us proud. Rick.
[Re: Tomswheels]
#1831286
05/21/15 03:21 AM
05/21/15 03:21 AM
Tomswheels
Escondido CA USA
Rick, I am excited, 7 cars is a full class, where can we see results? Did you get tires? I put the pic below of your car, and I agree on the sway bar vs K member, I was actually thinking of going back to the earlier 67-72 so I could go with a different sway bar...
[Re: Tomswheels]
#1831672
05/21/15 07:58 PM
05/21/15 07:58 PM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
Dan says you can install a 67-72 bar on a 73+ with a little fab work.
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: Tomswheels]
#1831945
05/22/15 02:38 AM
05/22/15 02:38 AM
norcal-fjo
Sacramento
Tom, I just finished running the nostalgia drags at Eagle Field, so my car still has the rallye wheels on it. I have the Dunlop star spec 2 on my autoX wheels, and they seem to work fine. I really don't have anything to compare them to, being my first set of "race" tires though. They are small at 245/45-17, but fit the car well. This should get you to the points page (if I did it right) SCCA Sac results Rick
[Re: moparx]
#1832329
05/22/15 05:28 PM
05/22/15 05:28 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
I believe this is called a knock-ometer no, the correct term for this is a "fine calibration" instrument. Yup. "Fine, DON'T FIT!" SMACK"FINE! DON"T GO IN!!!!" SMACK!!!"FINElly it went in, I KNEW it would!"
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: norcal-fjo]
#1832616
05/23/15 01:19 AM
05/23/15 01:19 AM
Tomswheels
Escondido CA USA
Tom, I just finished running the nostalgia drags at Eagle Field, so my car still has the rallye wheels on it. I have the Dunlop star spec 2 on my autoX wheels, and they seem to work fine. I really don't have anything to compare them to, being my first set of "race" tires though. They are small at 245/45-17, but fit the car well. This should get you to the points page (if I did it right) SCCA Sac results Rick Great to see you out there representing Rick, nice job!
[Re: Tomswheels]
#1832646
05/23/15 02:50 AM
05/23/15 02:50 AM
72Swinger
Nebraska
Is that the 67-72 bar? [/quote] Yes
