BB Rocker Arms? #182805
01/03/09 07:13 PM
01/03/09 07:13 PM
griff70440 Offline OP
with 440-1s besides jesel or t&d what is the next best rocker out there?I`m on a budget,so every penny counts.
thanks mike
Re: BB Rocker Arms? [Re: griff70440] #182806
01/03/09 07:15 PM
01/03/09 07:15 PM
Woodstock , Georgia
Mopar_racer_99 Offline
Woodstock , Georgia
Mike, what size cam , what spring pressure, what size springs, these things can mean the difference between being able to use the Harland Sharps and needing the Jesel, T&D's. John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: BB Rocker Arms? [Re: griff70440] #182807
01/03/09 07:15 PM
01/03/09 07:15 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Harland Sharp seems to be popular with some builders but they aren't inexpensive either.I decided to go with an old set of Isky irons and have them bushed and corrected at RAS.
Gus
64 Plymouth Savoy
Dana 60
Re: BB Rocker Arms? [Re: Mopar_racer_99] #182808
01/03/09 07:25 PM
01/03/09 07:25 PM
Pa
W
Wv68charger Offline
Wv68charger  Offline
W
Pa
HS's are nice pieces
Re: BB Rocker Arms? [Re: fourgearsavoy] #182809
01/03/09 07:30 PM
01/03/09 07:30 PM
Woodstock , Georgia
Woodstock , Georgia
wow, I just checked out the price of Harland Sharps complete set up $1090. Jesel are 1955 plus the 150 to mill and set up head. John
Re: BB Rocker Arms? [Re: fourgearsavoy] #182810
01/03/09 07:32 PM
01/03/09 07:32 PM
the current cam is 278/285@ 50 lift 700/680 its a roller.I`d like to go bigger if it will help the cars performance.
here is my current set up
400 to 511
4.25 stroke
6.535 rod
over 13.5-1
fully ported RPMs
rocker-Harlands
victor intake matched to heads
I`m hoping by changing the heads and intake (maybe the cam)
I`ll pick up a bit more Hp
thanks mike
Re: BB Rocker Arms? [Re: griff70440] #182811
01/03/09 07:34 PM
01/03/09 07:34 PM
Pa
W
Wv68charger Offline
Wv68charger  Offline
W
Pa
you have HS'S now? are thinking of changing ratios?
Re: BB Rocker Arms? [Re: Wv68charger] #182812
01/03/09 07:37 PM
01/03/09 07:37 PM
the -1s take a offset rocker,don`t they?
Re: BB Rocker Arms? [Re: griff70440] #182813
01/03/09 07:48 PM
01/03/09 07:48 PM
long island NY
Ari440 Online content
Ari440  Online Content
long island NY
440-1 harland sharp rockers are offset
1.39 9.85 - 137 mph
Re: BB Rocker Arms? [Re: Ari440] #182814
01/03/09 07:53 PM
01/03/09 07:53 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
I think he is putting -1s on and wants a cheaper offset rocker.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: BB Rocker Arms? [Re: Von] #182815
01/03/09 07:54 PM
01/03/09 07:54 PM
Pa
W
Wv68charger Offline
Wv68charger  Offline
W
Pa
hows the saying go: "pay a little now or alot later"
Re: BB Rocker Arms? [Re: Ari440] #182816
01/03/09 07:56 PM
01/03/09 07:56 PM
the intake rocker on the -1s are the only ones offset,right?
if thats the case,could I buy just the offset rockers and use the ones i have for the exhaust side?
mike
Re: BB Rocker Arms? [Re: Wv68charger] #182817
01/03/09 07:58 PM
01/03/09 07:58 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
if he used boost he could have the HP with a pulley change or wastegate twist.
sorry for the interuption.
Re: BB Rocker Arms? [Re: blownzoom440] #182818
01/03/09 08:10 PM
01/03/09 08:10 PM
long island NY
long island NY
what rollar cam lift and duration spring presure open and closed
this will determine what rocker to use
my 715/280 rollar took out two H/S rockers
soon I will have cnc 345s and will use jesel setup for them
1.39 9.85 - 137 mph
Re: BB Rocker Arms? [Re: griff70440] #182819
01/03/09 08:11 PM
01/03/09 08:11 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
The Harland Sharps will work just fine, I sell tons of them and have used them for over 20 years. When you get over the approximate 800-850 open pressure, its time for Jesel od T-D. Some of the H/S will go 1000#, but not the Mopars.
You could just re-use your exhaust rockers and buy intakes only.
I am going to run my annual H/S rocker deal starting next week. I can save you on a complete set or price just the intakes, but I think you'll see its worth your while to get a whole set as opposed to getting individual rockers.
I will shoot you a PM.
I'll advertise my sale at the beginning of the week.
Todd
RIP Monte Smith
Re: BB Rocker Arms? [Re: Ari440] #182820
01/03/09 08:13 PM
01/03/09 08:13 PM
Syracuse,NY
Syracuse,NY
ARI...those should have been fine. I have been running them for years on .780 cams and zero problems.
Do you still have the broken ones? I'd like to look at them if you dont mind..on my nickel.
RIP Monte Smith
Re: BB Rocker Arms? [Re: CompWedgeEngines] #182821
01/03/09 08:23 PM
01/03/09 08:23 PM
long island NY
long island NY
I have to look for them ,I migth have thrown them out ,not sure thougth
one rocker split in two and the other one was striped at the threads
I ended up putting a solid cam back for now
also the rockers had miles/runs on them
do they fagtige (sp) over a period of time ?
1.39 9.85 - 137 mph
Re: BB Rocker Arms? [Re: Ari440] #182822
01/03/09 08:36 PM
01/03/09 08:36 PM
Syracuse,NY
Syracuse,NY
Yes, they can definately fatigue. It makes more sense now that you mention they have "miles" on them. They are excellent pieces in my opinion, but like anything, yes they can break over time but I would have to assume they have had a more than useful life. I just dont see them break without an explanation of oil starvation, too much spring, binding conditions, plugged oil holes, over-revved etc.
I just took a set off a car last year that I know had 17 years on them. It did finally break one and it was time to call it quits.Put a new set on and hope the customer can get another 17 years!
RIP Monte Smith
Re: BB Rocker Arms? [Re: griff70440] #182823
01/03/09 09:55 PM
01/03/09 09:55 PM
AndyF Offline
AndyF  Offline
If you haven't already purchased the 440-1 heads then maybe consider going with the EZ heads instead. The EZ heads are capable of 800 hp when fully ported and they'll accept standard rocker arms. That means you can reuse your existing HS rocker arms and save some cash.
Re: BB Rocker Arms? [Re: AndyF] #182824
01/03/09 10:05 PM
01/03/09 10:05 PM
Syracuse,NY
Syracuse,NY
Thats a good thought as well. EZ's and SRs also use the standard rocker set up you have.
The -1s will obviously make more power if that is in the plans later on.
RIP Monte Smith
