Re: offset hole in crank pulley. [Re: dartman366] #182794
01/03/09 10:39 PM
01/03/09 10:39 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
Does that still hold true when you are running a crank trigger and the pulley is holding the relucter wheel on.
yes
Re: offset hole in crank pulley. [Re: jamesc] #182795
01/03/09 10:49 PM
01/03/09 10:49 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
6 bolts was made for 3 and 4 belts pullys with a lot of load on them like water pump-power steering pump-A/C-air pumps-alt--
Re: offset hole in crank pulley. [Re: jamesc] #182796
01/03/09 10:55 PM
01/03/09 10:55 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
yes
Re: offset hole in crank pulley. [Re: dartman366] #182797
01/03/09 11:33 PM
01/03/09 11:33 PM
Canada
CrAzYMoPaRGuY Offline
Canada
I use all six.
Three would just make me angry!!!!!!
CrAzYMoPaRGuY
Re: offset hole in crank pulley. [Re: Cab_Burge] #182798
01/03/09 11:58 PM
01/03/09 11:58 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Mopar cranks after about 1971 had an offset bolt in the damper/pulley mounting.
Actaully the offset hole in the dampeners and puleys where standard until around 1971, even pattern after that
OK you are right, I had it backwards but any way there was an offset set up and all we do is elongate the one hole slightly. Thanks for straightening it out for year sequence.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: offset hole in crank pulley. [Re: MoparforLife] #182799
01/04/09 02:24 AM
01/04/09 02:24 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I only use three...Gotta save weight where ever you can these days
Re: offset hole in crank pulley. [Re: Al_Alguire] #182800
01/04/09 10:28 AM
01/04/09 10:28 AM
The Grand State of Confusion-O...
SKR8PN Offline
SKR8PN  Offline
..couple of bolts here...couple of washers there...it all adds up
Karma has no menu. You get served what you deserve.
Re: offset hole in crank pulley. [Re: B G Racing] #182801
01/04/09 10:38 AM
01/04/09 10:38 AM
NC
440Jim Offline
440Jim  Offline
NC
We just use 3 grade 8 allen socket head bolts to hold it on(similar to a chevy)forget the rest of the holes.
I can't argue with that. I am running 3 grade 8 bolts myself. It looks wrong at first, but it is balanced and works just fine, but all I run off that pulley is my 60 amp alternator (electric fan). And I do have the MSD crank trigger wheel behind it. But you can just elongate the hole in the pulley too.
