72 dart brake light switch question #1827078
05/15/15 03:22 AM
05/15/15 03:22 AM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
Maybe it is obvious but being upside down never helps- is there an adjustment that can be done on a brake light switch on my 72 demon? I swapped to a new aftermarket MC and the pedal doesn't return quite as far. I already bent it a little I need an 1/8th" more.
What fastener should I be looking for? Is it a screw? Bolt? Machine screw? Nut&Bolt?
I don't want to hoseclamp a shim to the pedal but I will if I have to...
Thanks!
Re: 72 dart brake light switch question [Re: radar] #1827131
05/15/15 10:27 AM
05/15/15 10:27 AM
Andrewh Offline
Andrewh  Offline
I made an L or U shaped plate that bolted on to the pedal to extend how far back it went when it was up.
I couldn't get enough adjustment on the switch to move it.
since the pedal already had holes in it, it was a simple bolt on.
Re: 72 dart brake light switch question [Re: Andrewh] #1827144
05/15/15 10:59 AM
05/15/15 10:59 AM
What Andrew said, drill/tap/bolt something secure on there (on the pedal). Avoid bending the switch itself as it is too delicate
Re: 72 dart brake light switch question [Re: Andrewh] #1827287
05/15/15 03:21 PM
05/15/15 03:21 PM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
Thanks!
That's easy enough. Hopefully this thread can help the next fella out- my search didn't return much.
Re: 72 dart brake light switch question [Re: radar] #1827290
05/15/15 03:23 PM
05/15/15 03:23 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
The pedals aren't original to my '72 (swapped to manual) so I don't know what a real '72 setup looks like.
But mine has a bolt (on the right hand side of the pedal/steering column bracket assembly) that when loosened allows the switch to slide back and forth for adjustment. Is yours already all the way forward?
