Re: Is it ok to straighten a bent crank
[Re: duckblind]
#1825572
05/13/15 11:12 AM
05/13/15 11:12 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
No problem, very common procedure.
[Re: Supercuda]
#1825640
05/13/15 12:27 PM
05/13/15 12:27 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
No problem, very common procedure. If the crank breaks it will be during the straightening procedure.. Friends Z28 ( 69 - 302) came back in two pieces from the machine shop, back in the day.... An expensive setback when its your High School daily driver..LOL
[Re: duckblind]
#1825943
05/13/15 06:47 PM
05/13/15 06:47 PM
Posts: 8,882 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
It is a crude process where you put the crank on some V blocks in the hyd press and then you guess at how hard you have to push it. You have to push it past center so it springs back to dead even. Push it too far and it bends the other way. That's why it can take hours to get it dead on. However, breaking a "forged" crank by trying to straighten it is unlikely unless the thing is bent in half!! Cast cranks aren't worth trying and will snap - likely what happened to that chevy crank!
[Re: duckblind]
#1825949
05/13/15 07:10 PM
05/13/15 07:10 PM
Supercuda
About to go away
About to go away
up yours
Pretty sure a factory Chevy 302 had a forged crank.
[Re: duckblind]
#1826019
05/13/15 08:23 PM
05/13/15 08:23 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Nitriding could cause a crack. ok, let me clarify, straightening a crank that has been nitrided could cause it to crack. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1826042
05/13/15 08:42 PM
05/13/15 08:42 PM
Supercuda
About to go away
About to go away
up yours
Nitriding could cause a crack. ok, let me clarify, straightening a crank that has been nitrided could cause it to crack. Tim That would explain the 302 crank, they were nitrided.
[Re: Supercuda]
#1828422
05/17/15 12:36 PM
05/17/15 12:36 PM
minivan
Eugene, Oregon
Nitriding could cause a crack. ok, let me clarify, straightening a crank that has been nitrided could cause it to crack. Tim That would explain the 302 crank, they were nitrided. Yes the 302 crank was forged and I believe it had larger journals than the 283.. Remember the 302 was technically a 327 bore with a 283 crank.. Seems as if Chevy was on strike?? when this happened and as said above, this was his "daily" transportation so panic to get it fixed was happening.. NO 302 cranks around so we looked into using a 283 crank.. Wasn't gonna work...
[Re: duckblind]
#1828425
05/17/15 12:38 PM
05/17/15 12:38 PM
Supercuda
About to go away
About to go away
up yours
Yeah, the 302 used the 283 stroke but the larger journal sizes, and that it way more chevy info than I wanted to know.
[Re: Cab_Burge]
#1828549
05/17/15 03:27 PM
05/17/15 03:27 PM
Posts: 8,295 fredericksburg,va
cudaman1969
fredericksburg,va
As probally already mention whne you spin a rod bearing the heat warps the crankshaft, a forged steel crank will bend but it can, and should be be straighten in a press safely before grinding the mains or rod journals I had one 1969 440 crank out of a CA Hiway Patrol car that had spun a rod bearing, I took it to my crankshaft grinding company and watch them try to straighten it in the press before setting it up for grinding, that rascal broke in the middle Far better for it to break in half there than in the motor I always heard when a bearing spins it forms a crack from the heat, got a hemi Kellogg crank with that problem. Better check for cracks, mopar is famous for that.
[Re: cudaman1969]
#1829403
05/18/15 06:46 PM
05/18/15 06:46 PM
dogdays
Magnaflux it, using magnetic particle, not dye penetrant before it is ground, to see if it's worth saving. If it's been ground, dye penetrant should show you any cracks. That goes for any crank.
The overheating CAN cause cracks, really it's probably the uneven cooling that does it, but it doesn't have to. Lots of steel things are forged at red heat or a little hotter, and they don't have cracks. For example look at the Callies ad for its connecting rods where they show you a rod blank during the forging process.
If you can afford it I would strongly suggest getting a 4340 crank, either new or slightly used. It will be 50% or more stronger than the stock crank. I'd hate to waste all the machine work in a block to try to save a buck on the crank.
R.
[Re: cudaman1969]
#1829453
05/18/15 07:56 PM
05/18/15 07:56 PM
Posts: 43,230 Bend,OR USA
Cab_Burge
As probally already mention whne you spin a rod bearing the heat warps the crankshaft, a forged steel crank will bend but it can, and should be be straighten in a press safely before grinding the mains or rod journals I had one 1969 440 crank out of a CA Hiway Patrol car that had spun a rod bearing, I took it to my crankshaft grinding company and watch them try to straighten it in the press before setting it up for grinding, that rascal broke in the middle Far better for it to break in half there than in the motor I always heard when a bearing spins it forms a crack from the heat, got a hemi Kellogg crank with that problem. Better check for cracks, mopar is famous for that. As already pointed out heat from spinning a bearing can, not always, cause cracks. I have all my rotating parts magged before using them, I have had some cranks with cracks in the fillets ground out and welded up and then repaired In fact I have a old forged steel Bryant 4.5 stroke top fuel carnk with the center counterweights that is cracked in multiple places, I've got a bid of $800.00 to have it welded and repaired so it is uaseable in a street or mild bracket race motor.That crank has never spun a bearing that I can see any evidence of or the crank repair specialitis could see or tell of A new one like it starts at $3200.00 now so maybe I will have it fixed and use it
