Re: 1 full comp point increase is worth what? Dyno results insyd
[Re: Cab_Burge]
#1822751
05/09/15 04:16 PM
05/09/15 04:16 PM
Posts: 7,506 Az
Crizila
Az
Being from Bend, you don't count in the popularity contest. -1.
Fastest 300
[Re: RAMM]
#1823731
05/10/15 10:34 PM
05/10/15 10:34 PM
Posts: 1,682 Philadelphia
radar
Philadelphia
I understand the diminishing benefits of CR increase as you get into race gas territory but wild CRs will always be linked in my head with wild cams. Nobody with 15:1 compression is running the same cam intake or headers as the guy with 10.5 CR.
Which I guess gets into a dynamic compression discussion which will get in the weeds fast!
For sure the effect a part change has on a specific combo mostly only applies to that specific combination of parts and clearances. At the same time it is always nice to hear about this kind of stuff- especially on a fairly common motor/heads- thanks and I enjoyed the bench racing in the comments too!
