Page 1 of 3 1 2 3
1 full comp point increase is worth what? Dyno results insyd #1821935
05/08/15 05:04 PM
05/08/15 05:04 PM
The Great White North
RAMM Offline OP
RAMM  Offline OP
Like the title implies I had the chance to test a 440 RB @ 9.4 static compression ratio and then again (due to an oil leak) @ 10.4 static compression.
This is a 446 I recently built for a customer using '915 heads and flat top Wiseco forged pistons. It ran all right during the initial dyno session but the rear main was leaking a little and that was not acceptable so I took it off the dyno and couldn't leave it alone.
When I was assembling the engine the pistons measured .055" in the hole. Also understand the customer really wanted to save these pistons so I cleaned them up and CNC machined them with a slight conical dish netting a little more volume. Basically I knew there was plenty of room to play with here so I decked the block exactly .045" per side which put it @ 10.4 comp. I had the chance to re-dyno with NO other changes. The power increase is somewhat expected but the timing requirements changed dramatically. Previous timing for max power was 35-36 total--Now 30-31 total is all that it likes. Interesting to say the least. So +30 HP +38 ft/lbs at the peaks was observed--the graph tells a much better story. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: RAMM] #1821938
05/08/15 05:11 PM
05/08/15 05:11 PM
cleveland ohio
MartyQ Offline
MartyQ  Offline
cleveland ohio
Very coo ! Thanks for the info !
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: RAMM] #1821940
05/08/15 05:12 PM
05/08/15 05:12 PM
cleveland ohio
MartyQ Offline
MartyQ  Offline
cleveland ohio
Very cool ! Thanks for the info !
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: RAMM] #1821941
05/08/15 05:14 PM
05/08/15 05:14 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Wow, thanks for the info. What cam is he running?
I was contemplating shaving my heads for a bump of a half point to a point, this is good info and I think I'll pull those suckers off at the end of the season and shave them.
EDIT: Noticed you shaved the block and now it likes less timing. What was the before and after piston to head clearance?
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: RAMM] #1821943
05/08/15 05:16 PM
05/08/15 05:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Good info... from the testing I did.. the lower the starting
compression the bigger the gain... as in going from 9.1 to 10.1..
its a deminising return thing
wave
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: MR_P_BODY] #1821944
05/08/15 05:20 PM
05/08/15 05:20 PM
cleveland ohio
MartyQ Offline
MartyQ  Offline
cleveland ohio
Mr P body when does it start dropping off ?? 14.1 15.1 ?? Thxs !!!
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: GTX MATT] #1821947
05/08/15 05:27 PM
05/08/15 05:27 PM
RAMM Offline OP
RAMM  Offline OP
Lunati cam Lunati
Yes the block was decked .045" so the pistons are .010" in the hole now. J.Rob
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: RAMM] #1821951
05/08/15 05:29 PM
05/08/15 05:29 PM
RAMM Offline OP
RAMM  Offline OP
Peak power wound up like this 537 hp @ 5600 rpm and 564 ft/lbs @ 4300-4400 rpm. J.Rob
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: MartyQ] #1821952
05/08/15 05:30 PM
05/08/15 05:30 PM
RAMM Offline OP
RAMM  Offline OP
Thanks, I thought this was a pretty cool test. I have never had the opportunity to make only one change like this and re test. J.Rob
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: MR_P_BODY] #1821953
05/08/15 05:32 PM
05/08/15 05:32 PM
RAMM Offline OP
RAMM  Offline OP
wave
This is what I have come to understand as well. Also noteworthy is idle vacuum increased 2.5" as well from baseline. J.Rob
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: RAMM] #1821954
05/08/15 05:33 PM
05/08/15 05:33 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Did it go from having no quench to a real quench area with the milling? If so, I'd think that would have something to do with it needing less ignition lead.
Did the BSFC numbers improve, too?
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: MartyQ] #1821976
05/08/15 06:06 PM
05/08/15 06:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It drops all along when the compression is increased.. the higher
the compression the less the increase... its more like a bell curve
wave
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: PorkyPig] #1821988
05/08/15 06:13 PM
05/08/15 06:13 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
This is what I was getting at. .040 compressed head gasket?
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: MR_P_BODY] #1821994
05/08/15 06:24 PM
05/08/15 06:24 PM
P
PorkyPig Offline
PorkyPig  Offline
P
wave
David Vizard chart for estimating power increase % due to CR increase.
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: GTX MATT] #1822006
05/08/15 06:43 PM
05/08/15 06:43 PM
P
PorkyPig Offline
PorkyPig  Offline
P
Just looked and saw RAMM got a 6% increase, much higher than the Vizard chart I posted predicted. I suspect he found some "bonus points" by building quench into it, too.
Well, RAMM? grin
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: PorkyPig] #1822012
05/08/15 06:50 PM
05/08/15 06:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
And according to his chart its the same thing I said..
look at the higher compression points and it shows like 1% increase
and even lower
wave
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: MR_P_BODY] #1822021
05/08/15 06:57 PM
05/08/15 06:57 PM
P
PorkyPig Offline
PorkyPig  Offline
P
and even lower
wave
You also said it was like a bell curve, but it's not. It's just a simple case of diminishing returns.
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: PorkyPig] #1822023
05/08/15 06:57 PM
05/08/15 06:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well, RAMM? grin
I think that being he cut the deck to gain the point he made the
chamber more efficient over what it was.. that might give him the
higher % increase AND the lack of timing.. which the lack of timing
is efficiency
wave
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: RAMM] #1822029
05/08/15 07:05 PM
05/08/15 07:05 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
Would a switch to aluminum heads allowed you to keep running the 38 degrees of timing and resulted in even more of a power jump?
Re: 1 full comp point increase is worth what? Dyno results insyd [Re: 67Satty] #1822039
05/08/15 07:15 PM
05/08/15 07:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
JMO but if you ran higher timing on the alum head VS less timing
on a iron head that it would be the same.. if both heads were the
same thing and just different material... again... JMO
wave
Page 1 of 3 1 2 3
