New bullet, W5, 408 injected on alky #182155
01/03/09 12:24 AM
01/03/09 12:24 AM
oregon
greendart408 Offline OP
oregon
A pic of what I have been busy doing the last few months.
Re: New bullet, W5, 408 injected on alky [Re: greendart408] #182156
01/03/09 12:29 AM
01/03/09 12:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Very nice, is that a Keiser mech injection system
Re: New bullet, W5, 408 injected on alky [Re: MR_P_BODY] #182157
01/03/09 12:37 AM
01/03/09 12:37 AM
oregon
oregon
Mr P. No it is a rons toilet system.
Re: New bullet, W5, 408 injected on alky [Re: greendart408] #182158
01/03/09 12:46 AM
01/03/09 12:46 AM
Poulsbo, WA
ChrisJohnston669 Offline
Poulsbo, WA
That thing is going to be sick. Did you get some fuel additives. What smell would you go with?
Re: New bullet, W5, 408 injected on alky [Re: ChrisJohnston669] #182159
01/03/09 12:51 AM
01/03/09 12:51 AM
oregon
oregon
I havent thought about that yet. hah! Trying to get it together so I can mock up my belt drive pump and have to build a fuel cell that fits the angle of the stock inner fender.
Re: New bullet, W5, 408 injected on alky [Re: greendart408] #182160
01/03/09 03:15 AM
01/03/09 03:15 AM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Sweet.....
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: New bullet, W5, 408 injected on alky [Re: racerhog] #182161
01/03/09 11:36 AM
01/03/09 11:36 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Looks familiar
Re: New bullet, W5, 408 injected on alky [Re: RyanJ] #182162
01/03/09 11:38 AM
01/03/09 11:38 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Re: New bullet, W5, 408 injected on alky [Re: ProSport] #182163
01/03/09 11:42 AM
01/03/09 11:42 AM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
How about a little info on the motor, what weight car it is going in, etc
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: New bullet, W5, 408 injected on alky [Re: B3422W5] #182164
01/03/09 12:07 PM
01/03/09 12:07 PM
oregon
oregon
It is going in a 69 dart with ladder bars, and coilovers. It weighed 3050lbs race ready before with w2s on it. It should be 2975 or so with the w5s or so I am hopeing. I have lost a little weight also . Motor is 408ci, 14-1comp,SDSS max effort w5s with a 683,728 roller. IT has a 727 trans with a 5200 vert. Hopefully it will run.
Re: New bullet, W5, 408 injected on alky [Re: greendart408] #182165
01/03/09 12:17 PM
01/03/09 12:17 PM
Portage,michigan
Portage,michigan
I have a good friend with a 66 cuda, older indy heads, 379 motor, 13.5 compression, custom headers, 3100 with him in it, ladders, 727.
He has a flying toilet on his, alky.
He has been in the high 9.40's with it.139 mph.
I would suspect at your weight car should go 35 to 50 or so
1.41 best 60 foot
6.56 at 104.17
Re: New bullet, W5, 408 injected on alky [Re: B3422W5] #182166
01/03/09 12:28 PM
01/03/09 12:28 PM
oregon
oregon
I hope you are right Don as this is what I am hopeing it will run, as well as what Ryan J said also.
Re: New bullet, W5, 408 injected on alky [Re: greendart408] #182167
01/03/09 12:37 PM
01/03/09 12:37 PM
Portage,michigan
Portage,michigan
At one time, the guy with the 66 cuda was running 9.68 to 9.72 or so(he later, with a cam change, more porting, etc got in the high 40's)but anyhow, when he was running high 60's low 70's, one afternoon we swapped on my 1100 pro systems dominator and ran the car on race gas. He made one lap like that(we didnt have everything perfect, i am sure, and he went 10 flat.
My thinking is that the flying toilet and alky is about 3 tenths better than a well scienced out dominator on gas.
I go 9.80s in good air with mine on leafs at 3350, so you are lighter and have the toilet, i dont doubt you will go 40's without working up a sweat, maybe some 30's
Sound like you have a very good combination, should go 1.27- 1.28 60 foot or so.
You are gong to be surprised how snappy the throttle is, and how much torque that toilet will provide, hope you have wheelie bars, cause it will want to get up on them...lol
1.41 best 60 foot
6.56 at 104.17
Re: New bullet, W5, 408 injected on alky [Re: B3422W5] #182168
01/03/09 12:50 PM
01/03/09 12:50 PM
oregon
oregon
I dont have any wheelie bars Don, street car, probably wont go far now though . Have you ever known anyone that has ran that m1 tunnel ram? I am thinking that might give me a gain as well?
Re: New bullet, W5, 408 injected on alky [Re: greendart408] #182169
01/03/09 12:54 PM
01/03/09 12:54 PM
Portage,michigan
Portage,michigan
No, cant say as i have.
My guess is that the car wont mind it a bit, any torque it kills off is more than offset by your alky injection, and it should pull like a freight train on the big end.
Just be patient tuning that thing, i am guessing it will take a while to sort it all out. But once you do, hang on
Jonny(the guy with the 66 379 stroke cuda)beats the urine out of that thing, runs it 7800 to 8000 every pass
1.41 best 60 foot
6.56 at 104.17
Re: New bullet, W5, 408 injected on alky [Re: B3422W5] #182170
01/03/09 01:07 PM
01/03/09 01:07 PM
oregon
oregon
I am going to try to dyno it at the place that Andy F does his dynoing. They are good guys there and real smart with alky injected stuff. This way it will be close at least when I get it to the track. I turned my old w2 stuff to 7500 every pass. I want to keep the revs down if I can. Stock block. I crossed at 7450 with old combo at 134.80 with 29.5 tire. What gear do you guys think with the new combo?? 4.30s or 4.10s??
Re: New bullet, W5, 408 injected on alky [Re: greendart408] #182171
01/03/09 01:56 PM
01/03/09 01:56 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
Good luck with it, I had one kinda like it
Re: New bullet, W5, 408 injected on alky [Re: greendart408] #182172
01/03/09 02:19 PM
01/03/09 02:19 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Very, very nice indeed.........should do the trick I would think.
Re: New bullet, W5, 408 injected on alky [Re: greendart408] #182173
01/03/09 02:42 PM
01/03/09 02:42 PM
NC
440Jim Offline
440Jim  Offline
NC
Twin Toilets on a Tunnel ram.
That has a ring to it!
What size are those toilets?
3.75" 1240 CFM
4.0" 1435 CFM
4.1" 1800 CFM
Did they set you up with a #0 or #0.5 pump?
Re: New bullet, W5, 408 injected on alky [Re: 440Jim] #182174
01/03/09 02:52 PM
01/03/09 02:52 PM
oregon
oregon
3.75" 1240 CFM
4.0" 1435 CFM
4.1" 1800 CFM
They are two 3.75 toilets. and a #0.5 pump
