Re: New bullet, W5, 408 injected on alky
[Re: MR_P_BODY]
#182157
01/03/09 12:37 AM
01/03/09 12:37 AM
Posts: 1,073 oregon
greendart408
oregon
Very nice, is that a Keiser mech injection system
Mr P. No it is a rons toilet system.
[Re: ChrisJohnston669]
#182159
01/03/09 12:51 AM
01/03/09 12:51 AM
Posts: 1,073 oregon
greendart408
oregon
That thing is going to be sick. Did you get some fuel additives. What smell would you go with?
I havent thought about that yet. hah! Trying to get it together so I can mock up my belt drive pump and have to build a fuel cell that fits the angle of the stock inner fender.
[Re: ProSport]
#182163
01/03/09 11:42 AM
01/03/09 11:42 AM
Posts: 11,720 Portage,michigan
B3422W5
Portage,michigan
How about a little info on the motor, what weight car it is going in, etc
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#182164
01/03/09 12:07 PM
01/03/09 12:07 PM
Posts: 1,073 oregon
greendart408
oregon
It is going in a 69 dart with ladder bars, and coilovers. It weighed 3050lbs race ready before with w2s on it. It should be 2975 or so with the w5s or so I am hopeing. I have lost a little weight also . Motor is 408ci, 14-1comp,SDSS max effort w5s with a 683,728 roller. IT has a 727 trans with a 5200 vert. Hopefully it will run.
[Re: greendart408]
#182165
01/03/09 12:17 PM
01/03/09 12:17 PM
B3422W5
Portage,michigan
I have a good friend with a 66 cuda, older indy heads, 379 motor, 13.5 compression, custom headers, 3100 with him in it, ladders, 727. He has a flying toilet on his, alky. He has been in the high 9.40's with it.139 mph.
I would suspect at your weight car should go 35 to 50 or so
[Re: B3422W5]
#182166
01/03/09 12:28 PM
01/03/09 12:28 PM
Posts: 1,073 oregon
greendart408
oregon
I hope you are right Don as this is what I am hopeing it will run, as well as what Ryan J said also.
[Re: greendart408]
#182167
01/03/09 12:37 PM
01/03/09 12:37 PM
B3422W5
Portage,michigan
At one time, the guy with the 66 cuda was running 9.68 to 9.72 or so(he later, with a cam change, more porting, etc got in the high 40's)but anyhow, when he was running high 60's low 70's, one afternoon we swapped on my 1100 pro systems dominator and ran the car on race gas. He made one lap like that(we didnt have everything perfect, i am sure, and he went 10 flat.
My thinking is that the flying toilet and alky is about 3 tenths better than a well scienced out dominator on gas. I go 9.80s in good air with mine on leafs at 3350, so you are lighter and have the toilet, i dont doubt you will go 40's without working up a sweat, maybe some 30's
Sound like you have a very good combination, should go 1.27- 1.28 60 foot or so.
You are gong to be surprised how snappy the throttle is, and how much torque that toilet will provide, hope you have wheelie bars, cause it will want to get up on them...lol
[Re: B3422W5]
#182168
01/03/09 12:50 PM
01/03/09 12:50 PM
Posts: 1,073 oregon
greendart408
oregon
I dont have any wheelie bars Don, street car, probably wont go far now though . Have you ever known anyone that has ran that m1 tunnel ram? I am thinking that might give me a gain as well?
[Re: greendart408]
#182169
01/03/09 12:54 PM
01/03/09 12:54 PM
B3422W5
Portage,michigan
No, cant say as i have.
My guess is that the car wont mind it a bit, any torque it kills off is more than offset by your alky injection, and it should pull like a freight train on the big end.
Just be patient tuning that thing, i am guessing it will take a while to sort it all out. But once you do, hang on
Jonny(the guy with the 66 379 stroke cuda)beats the urine out of that thing, runs it 7800 to 8000 every pass
[Re: 440Jim]
#182174
01/03/09 02:52 PM
01/03/09 02:52 PM
Posts: 1,073 oregon
greendart408
oregon
Twin Toilets on a Tunnel ram.
That has a ring to it!
What size are those toilets? 3.75" 1240 CFM 4.0" 1435 CFM 4.1" 1800 CFM
Did they set you up with a #0 or #0.5 pump?
They are two 3.75 toilets. and a #0.5 pump
[Re: greendart408]
#182175
01/03/09 02:56 PM
01/03/09 02:56 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
What Guts are in it?? Crank, Rods, Pistons, and what block you using?
[Re: greendart408]
#182177
01/03/09 04:05 PM
01/03/09 04:05 PM
B3422W5
Portage,michigan
Mp, scat 4340 4in crank, eagle 6.200 rod, je pistons. Stock block, sonic checked with pro gram billet splayed caps.
Just so you know, with the 650-680 horse you are throwing at that block, it will split.
Its a definate mistake...sorry gotta say that
[Re: B3422W5]
#182179
01/03/09 08:26 PM
01/03/09 08:26 PM
Posts: 426 Cairns Queensland Australia. T...
vc360
It sounded like it was a killer combo till the stock block bit. Don have you broken a stock block before?
