Time for tires. Bias or radials? Suggesions #1816237
05/01/15 12:08 PM
05/01/15 12:08 PM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
Since 2004 I've had drag radials on my Duster BFG radial T/A on the front and their drag radials out back. In 2012 I bought new BFG drag radials for the back. For some reason the new set is already worn down to the chords even though they were not even used like the old set. Now it's time for new rubber.
The car goes to the strip a few times a year and then is street driven all summer. I want a sticky tire and don't want to deal with switching to slicks when I race so the tire has to be a DOT type. I've been looking at MT ET streets, Hoosier quick time pro DOT, M&H you name it. Both in the bias and radial forms.
The Duster is about 3200 lbs, about 530-550hp 440, super stock springs, manual 727 with 3.73 Dana. I've been running 275/60 in back and 215/60 up front. I'd like a slightly taller tire up front and because of stock wheel wells and spring location the 275's are about it for size. Wheels are 15x6 and 15x8.5 American torque thrust D's
Sorry about the length but I need some suggestions please. Thanks
Re: Time for tires. Bias or radials? Suggesions [Re: rck850] #1816247
05/01/15 12:24 PM
05/01/15 12:24 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
For the front, go with a 215-70, or 205-70.
If you were satisfied w/ the BFG drag radials, then you'll be REAL happy with the M/T ET Street radials. The M/T radials hook WAY better.
The 3754R is the traditional 275-60 drag radial and what I'd recommend.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Time for tires. Bias or radials? Suggesions [Re: rck850] #1816293
05/01/15 01:22 PM
05/01/15 01:22 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
For my Street/Strip 500hp 73 Duster, I have two sets of rears, on their own wheels, that we always switch out.. 275-60-15 BFG T/A and Mickey Thompson Drag Radials..
The T/A's will not hook on the street.. I've gotten the car sideways when stabbing the throttle at 60 mph.. smile But they hold up over the miles and they give the car the "Street Car" look...
The M/T's are a sticky tire that gives a 1.4/1.5 60' time, which is not bad for a street car with stock suspension.. However they do not last on the street..
So its pretty much up to you.. If you're ok with spending $500-$600 on tires every 500 miles or so... then MT are the answer..
Re: Time for tires. Bias or radials? Suggesions [Re: rck850] #1816294
05/01/15 01:22 PM
05/01/15 01:22 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
M/T has some new drag radial tires out, you may want to check them out.
http://www.mickeythompsontires.com/pressreleasepage.php?id=365
Re: Time for tires. Bias or radials? Suggesions [Re: rck850] #1816301
05/01/15 01:30 PM
05/01/15 01:30 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
M/T ET Streets here and I love them.
Re: Time for tires. Bias or radials? Suggesions [Re: dustergirl340] #1816583
05/01/15 07:23 PM
05/01/15 07:23 PM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
Thanks guys! I'm leaning more toward the radials just because that's all that's ever been on the car. That new MT tire isn't even listed on summit's website. For a front I was looking at a 205/70 Goodyear Assurance Fuel Max.
Re: Time for tires. Bias or radials? Suggesions [Re: rck850] #1816746
05/01/15 11:13 PM
05/01/15 11:13 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Are your front tires radials ? I ask because I run a 215/75-15 standard street radial tire up front and when I went to a radial tire it handles much better all around them when I uses a bias tire in the back. I used Hoosier QTP tires which are not a radial and the car would give a little wonder in the traps. I switched to a 30 x 9 Hoosier radial slick and it handles great now with no wonder at all. I run the Hoosier radial slick on the street and have been for over 4 years but myself I would want to go radial if you run radial up front. Maybe not if you run a bias tire up front. I prefer the way my car handles on radial tires all around. Ron
Re: Time for tires. Bias or radials? Suggesions [Re: 383man] #1816823
05/02/15 01:02 AM
05/02/15 01:02 AM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
That was the main thing I wanted to avoid was mixing tires. The fronts are radials now and if I was going with bias in the rear I'd be using bias up front too.
Re: Time for tires. Bias or radials? Suggesions [Re: rck850] #1816827
05/02/15 01:09 AM
05/02/15 01:09 AM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I am running bias tires on the front and drag radials on the back with no problems. A few weeks ago I had slicks on the back and I did not like the way it handled. Like the drag radials better.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Time for tires. Bias or radials? Suggesions [Re: rck850] #1816877
05/02/15 02:28 AM
05/02/15 02:28 AM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
Et street radial and be done. Good set of adjustable rear shocks on the back and let it eat.
Re: Time for tires. Bias or radials? Suggesions [Re: rck850] #1816950
05/02/15 10:37 AM
05/02/15 10:37 AM
Locomotion Offline
Locomotion  Offline
I don't have any experience with Hoosier's street legal drag tires, but I've heard of people speak well of them. I do run their radial drag slicks and have had great, consistent results. Here are their offerings:
Hoosier drag tires.
Re: Time for tires. Bias or radials? Suggesions [Re: rck850] #1818043
05/03/15 10:33 PM
05/03/15 10:33 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I bought the Hoosier drag radials for my car. Really liked the QTP's on a previous car so I wanted to give Hoosier my business.
I like them thus far. One thing of note, they are about 10 pounds each lighter than comparable Mickey's are.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Time for tires. Bias or radials? Suggesions [Re: B3422W5] #1821256
05/07/15 07:29 PM
05/07/15 07:29 PM
Ohio
rck850 Offline OP
rck850  Offline OP
Ohio
I made my decision on fronts. I went with a Firestone FR710 in 205/70-15. The rears I am going to get in a few days I'm probably going with M&H Drag radials in 275/60-15. I'll post pics up when they are all mounted. Thanks guys for all the suggestions up
