preparing for oiling sb mods #1817973
05/03/15 09:27 PM
05/03/15 09:27 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
ok, preparing for oiling mods on my 71' 360 block. ordered the 1/2" and 9/32x12" drill bits. most of my 1/2" oil passages were done way back, so wont have to spend much time there. I will be opening up the passages to the mains with the 9/32" bit, leaving the cam passages as they are and blocking passage to driver side at #1 main, but leaving tube out of pass side. oil to heads will be restricted to .060 as I spray bar oil(previously blocked). hows that? think it will be good to 7500rpm?
Re: preparing for oiling sb mods [Re: mopar dave] #1818254
05/04/15 06:24 AM
05/04/15 06:24 AM
pennsylvania
poboyengineering Offline
pennsylvania
When I did mine, I first went through the main passages with 1/4" bit, just to clean out anything that might have been in there, then hit it with the 9/32. Call me paranoid, but to quote the instructions from McCandless, "...if you break off the bit in there, then you have real problems."
Worked for me, and made me feel a lot better about drilling on a perfectly good block!
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: preparing for oiling sb mods [Re: mopar dave] #1818263
05/04/15 07:56 AM
05/04/15 07:56 AM
Guitar Jones Offline
Yes take your time and go slow. If you break a bit off you might as well junk the block because you will probably never get it out.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: preparing for oiling sb mods [Re: mopar dave] #1818308
05/04/15 10:29 AM
05/04/15 10:29 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I've been working on my R1 block, most of the passages were already 1/2" so just a little drilling there. I've also drilled the passengers side main bearing feeds to 9/32". Still haven't made my mind up on opening up the #2 & #4 cam bearing feeds from the mains. I'm going to pick up a 1/4" set screw to plug the feed to the drivers side and also the fittings for the crossover, think I'll use a 1/4" hard line for it.
Re: preparing for oiling sb mods [Re: justinp61] #1818311
05/04/15 10:41 AM
05/04/15 10:41 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
The #1 single most important mod to the SB is to port and polish the #5 cap main oil feed entry passage and I also port, polish, debur and chamfer the internals of the oil pump.
WIZE
In Car:
Re: preparing for oiling sb mods [Re: Streetwize] #1818319
05/04/15 10:57 AM
05/04/15 10:57 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I forgot to mention that, mine is drilled and port matched, going to reuse the pump off my 408 as it's already been ported. One more thing is where the oil returns to the block from the filter, it has to make a 90* turn in the block. I blend the back of the 90 to smooth the oil flow
Re: preparing for oiling sb mods [Re: mopar dave] #1818327
05/04/15 11:06 AM
05/04/15 11:06 AM
Mt Morris Michigan
Mt Morris Michigan
ok, thanks for all the info here. I will definitely take my time with this. so would it be better to spin the drill at low speed?
Re: preparing for oiling sb mods [Re: mopar dave] #1818334
05/04/15 11:11 AM
05/04/15 11:11 AM
Columbus, GA
Michael Ecks Offline
Columbus, GA
sorry to hijack but where did you order the bits from. need to do all of this to mine soon.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: preparing for oiling sb mods [Re: Michael Ecks] #1818350
05/04/15 11:37 AM
05/04/15 11:37 AM
Mt Morris Michigan
Mt Morris Michigan
ebay. aircraft drill bits.
Re: preparing for oiling sb mods [Re: mopar dave] #1818524
05/04/15 02:53 PM
05/04/15 02:53 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Just open up #2,#3,and#4 oil feeds to the mains. I don't drill #1 as it only feeds one rod. Don't do the cam bearing feeds either. If you do anything to cam bearings , drill a new 3/32" hole in cam bearing opposite the original hole, and install with new 3/32" hole lined up with feed hole. You have to install #2 and #4 cam bearings as is, because of rocker oiling on sm. blocks. 3/32" hole is plenty, even on street applications.
I would not restrict oil to rocker arms. Chryslers timed oiling works pretty well. If anything, some builders put a small groove on the #2 and #4 cam journal to give a small amount of oil to rockers full time. The old mushroom cores have the groove already on the #2 and #4 journals.
And as stated in one of the replys, the oil path from oil filter, cleaning out the 90* corner in bottom of center hole especially the short turn helps a bunch. Also the cap and pump work as suggested.
Re: preparing for oiling sb mods [Re: qwkmopardan] #1818549
05/04/15 03:17 PM
05/04/15 03:17 PM
Mt Morris Michigan
Mt Morris Michigan
ok, 2,3,4 main oil feeds only. thanks for that. I have been spray bar oiling the top end(valve,rockers,etc) for 8+yrs with the oil passage to the heads plugged. just gonna drill a .060" hole in the plugs just for piece of mind.
Re: preparing for oiling sb mods [Re: mopar dave] #1818571
05/04/15 03:47 PM
05/04/15 03:47 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Any pics of your spray bar setup?
68 Barracuda Formula S 340
Re: preparing for oiling sb mods [Re: Bad340fish] #1818666
05/04/15 06:10 PM
05/04/15 06:10 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Is there a proven way to restrict oil to the rocker shafts WITHOUT having to pull the heads to insert a restrictor?
I've wondered if a proper length spacer sleeve that has a 5/16 ID but with an OD smaller than the shaft hold down holes could work. Just insert it through the pedestal to reduce the full flow to the shafts.
WIZE
In Car:
Re: preparing for oiling sb mods [Re: Bad340fish] #1818775
05/04/15 08:14 PM
05/04/15 08:14 PM
Mt Morris Michigan
Mt Morris Michigan
Not at the moment but it was bought and installed at BLP.
Re: preparing for oiling sb mods [Re: Streetwize] #1818779
05/04/15 08:16 PM
05/04/15 08:16 PM
Mt Morris Michigan
Mt Morris Michigan
I can restrict it at the block deck or in the pedestal on the indy head. That passage is already threaded.
Re: preparing for oiling sb mods [Re: mopar dave] #1818939
05/04/15 11:23 PM
05/04/15 11:23 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
7500? What crank?
Re: preparing for oiling sb mods [Re: mopar dave] #1818991
05/04/15 11:57 PM
05/04/15 11:57 PM
pennsylvania
pennsylvania
My cap is done, and the block is too. Does anyone have pictures of the pump cleanup? I have an idea of what to do, but some guidance would be helpful.
Re: preparing for oiling sb mods [Re: CMcAllister] #1819060
05/05/15 12:55 AM
05/05/15 12:55 AM
Mt Morris Michigan
Mt Morris Michigan
7500 would be max shift point and may be 7000. 4" eagle forged.
Re: preparing for oiling sb mods [Re: poboyengineering] #1819064
05/05/15 12:57 AM
05/05/15 12:57 AM
Mt Morris Michigan
Mt Morris Michigan
Re: preparing for oiling sb mods [Re: mopar dave] #1819075
05/05/15 01:06 AM
05/05/15 01:06 AM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
I don't have any experience with that crank but I've had 2 engines with the stock iron crank and at 7400 I couldn't keep rod bearings in them until I took the oil supply for the heads completely off of the cam.
