Re: preparing for oiling sb mods
[Re: mopar dave]
#1818254
05/04/15 06:24 AM
05/04/15 06:24 AM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
When I did mine, I first went through the main passages with 1/4" bit, just to clean out anything that might have been in there, then hit it with the 9/32. Call me paranoid, but to quote the instructions from McCandless, "...if you break off the bit in there, then you have real problems." Worked for me, and made me feel a lot better about drilling on a perfectly good block!
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
[Re: mopar dave]
#1818263
05/04/15 07:56 AM
05/04/15 07:56 AM
Posts: 20,625 in a cattle trailer down by th...
Guitar Jones
Yes take your time and go slow. If you break a bit off you might as well junk the block because you will probably never get it out.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Streetwize]
#1818319
05/04/15 10:57 AM
05/04/15 10:57 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
The #1 single most important mod to the SB is to port and polish the #5 cap main oil feed entry passage and I also port, polish, debur and chamfer the internals of the oil pump. I forgot to mention that, mine is drilled and port matched, going to reuse the pump off my 408 as it's already been ported. One more thing is where the oil returns to the block from the filter, it has to make a 90* turn in the block. I blend the back of the 90 to smooth the oil flow
[Re: mopar dave]
#1818334
05/04/15 11:11 AM
05/04/15 11:11 AM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
sorry to hijack but where did you order the bits from. need to do all of this to mine soon.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: mopar dave]
#1818571
05/04/15 03:47 PM
05/04/15 03:47 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
Any pics of your spray bar setup?
68 Barracuda Formula S 340
[Re: mopar dave]
#1818991
05/04/15 11:57 PM
05/04/15 11:57 PM
poboyengineering
pennsylvania
My cap is done, and the block is too. Does anyone have pictures of the pump cleanup? I have an idea of what to do, but some guidance would be helpful.
[Re: mopar dave]
#1819075
05/05/15 01:06 AM
05/05/15 01:06 AM
Posts: 11,521 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
7500 would be max shift point and may be 7000. 4" eagle forged. I don't have any experience with that crank but I've had 2 engines with the stock iron crank and at 7400 I couldn't keep rod bearings in them until I took the oil supply for the heads completely off of the cam.
