9-1/4 YOKE SIZE #1817018
05/02/15 12:57 PM
05/02/15 12:57 PM
Finally a HUSKER again
Moparnut426 Offline OP
I want to change over to a 1350 style u-joint on the ramcharger. Its a big block 440 sixpac and its not being nice to the lil 7260 u-joints on the rear driveshaft.
I see Randys ring and pinion will sell a 1350 strap style yoke for a Dana 44, but I don't see one for the 9-1/4.
Anyone know what the best way around this is?
Ill have the rear shaft made custom so Im not worried about that.
Kasey
Re: 9-1/4 YOKE SIZE [Re: Moparnut426] #1817020
05/02/15 01:00 PM
05/02/15 01:00 PM
Will a Yoke from a 8-3/8 with the 1350 style u-joint and 29 splines work?
I cant fine a outside seal diameter for it.
That's my hickup
Re: 9-1/4 YOKE SIZE [Re: Moparnut426] #1817074
05/02/15 02:36 PM
05/02/15 02:36 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
29-spline 8 3/4" uses the same yoke as the 9 1/4". If you'll settle for u-bolts instead of straps try Doc Diff.
http://www.doctordiff.com/1350-u-bolt-pinion-yoke-package.html
Re: 9-1/4 YOKE SIZE [Re: Moparnut426] #1818485
05/04/15 02:18 PM
05/04/15 02:18 PM
OK, I have that kit only a 10 spline on my 489 case 8-3/4...
What about the flange at the T-Case? How would I get this to a larger U-Joint?
