B1 tunnel ram #1811743
04/25/15 05:58 PM
04/25/15 05:58 PM
Gearbox Offline OP
Gearbox  Offline OP
Hey folks, would anyone have any feedback on the cast aluminum B1 tunnel ram intakes that Koffels sold approx 14 years ago? I seen one today and was wondering what it would be worth and how well they worked? This one is brand new and never been assembled still has a solid top (no carb holes). Feedback appreciated.
Re: B1 tunnel ram [Re: Gearbox] #1811768
04/25/15 06:37 PM
04/25/15 06:37 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Heavier than heck. Uglier than dog poop but Tom Hemphill told me they work pretty good. I sold mine as he said the single 4intake works good too
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: B1 tunnel ram [Re: Gearbox] #1811777
04/25/15 06:45 PM
04/25/15 06:45 PM
Cincinnati OH
Bishop Offline
Bishop  Offline
Cincinnati OH
I was wondering the same thing, baught one years ago never did use it still laying in garage
Re: B1 tunnel ram [Re: Gearbox] #1811796
04/25/15 07:18 PM
04/25/15 07:18 PM
Gearbox Offline OP
Gearbox  Offline OP
I thought it was just me, it did look ugly. The top plate looked like the carbs would be sitting on a angle, not sideways or straight. I see all the sheetmetal intakes but wonder if a cast Indy or M1 tunnel ram could have the ports opened up to be used on B1 heads? I agree the single B1 intake is probably the way to go, just looking for the cast tunnel ram nostalgia look. May just be easier to build a Indy setup and pass on the b1's.
Re: B1 tunnel ram [Re: Gearbox] #1811801
04/25/15 07:30 PM
04/25/15 07:30 PM
PA.
"Little"John
"Little"John
PA.
Mine will be B1's this time
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: B1 tunnel ram [Re: Gearbox] #1811925
04/25/15 10:40 PM
04/25/15 10:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Just angled lines up a throttle bore with a port
wave
Re: B1 tunnel ram [Re: Gearbox] #1812026
04/26/15 12:14 AM
04/26/15 12:14 AM
Gearbox Offline OP
Gearbox  Offline OP
Thanks now that makes sense to me. I would imagine the throttle linkage would be a thing of beauty as well smile if I proceed with this deal, I think the tunnel ram will become garage art. I can only assume when you cut the holes in the top plate for carbs, you'd use a gasket as a stencil and possibly a milling machine to open the holes?
Re: B1 tunnel ram [Re: Gearbox] #1812125
04/26/15 03:48 AM
04/26/15 03:48 AM
Memphis TN
B1HEAD_USER Offline
B1HEAD_USER  Offline
Memphis TN
You will also need the mill to do the gasket surface on the bottom of the runners and the top if you want the top removable. I have one on mine seems to work good but really have nothing to compare it to since I run alcohol injection on the tunnel ram and ran a gas carb on the single 4 intake. I was able to do all the machine work and welding myself. They also need a lot of work in the runners as they are cast straight with little to no taper.
Re: B1 tunnel ram [Re: B1HEAD_USER] #1812315
04/26/15 02:22 PM
04/26/15 02:22 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I have one. With 2 dominators and 800hp nos kit its like carrying an engine block around lol. I will use it "one day..."
Re: B1 tunnel ram [Re: RemCharger] #1813275
04/27/15 07:34 PM
04/27/15 07:34 PM
Cincinnati OH
Bishop Offline
Bishop  Offline
Cincinnati OH
Yes heavy can be made into B or RB block 4150 carbs or 4500 Doms
Re: B1 tunnel ram [Re: Bishop] #1813482
04/27/15 11:00 PM
04/27/15 11:00 PM
Melbourne , Australia
LA360 Online boogie
LA360  Online Boogie
A friend has one, I have been in his ear to dig it out and I can machine it for him.
Re: B1 tunnel ram [Re: LA360] #1817659
05/03/15 01:09 PM
05/03/15 01:09 PM
PA.
"Little"John
"Little"John
PA.
Found some old pictures
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: B1 tunnel ram [Re: pittsburghracer] #1817660
05/03/15 01:10 PM
05/03/15 01:10 PM
PA.
"Little"John
"Little"John
PA.
2.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: B1 tunnel ram [Re: pittsburghracer] #1817661
05/03/15 01:11 PM
05/03/15 01:11 PM
PA.
"Little"John
"Little"John
PA.
3.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: B1 tunnel ram [Re: Gearbox] #1817676
05/03/15 01:36 PM
05/03/15 01:36 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
That does look crazy heavy
Re: B1 tunnel ram [Re: Gearbox] #1818959
05/04/15 11:41 PM
05/04/15 11:41 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
did you call GEORGE on the B1 HEADS
1.39 9.85 - 137 mph
Re: B1 tunnel ram [Re: Ari440] #1819110
05/05/15 01:45 AM
05/05/15 01:45 AM
Gearbox Offline OP
Gearbox  Offline OP
Yes, we've both been busy.PM sent, all is good.
Thanks.
