Drum to disc conversion
#1817538
05/03/15 09:36 AM
05/03/15 09:36 AM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
Hi all
I have power drums on my 72 road runner but want to upgrade to disc brakes. Which kit out there works with 14" inch front wheels? Also since I have a brake booster do I need to change that as well when changing out master cylinder or not?
Mikey
1969 Dodge Dart Swinger
Re: Drum to disc conversion
[Re: MikeyT]
#1817553
05/03/15 10:21 AM
05/03/15 10:21 AM
Posts: 7,664 IN
ahy
IN
The disk upgrade can be done with OE parts from the JY and auto parts store or in kit form with OE type parts. Basics are covered in the MA link below. Dr Diff offers the parts in kit form and is good to deal with IMO. The upgrade can be done with your current spindles or (better) with later 70's spindles which take bigger bearings. There are lots of upgrades beyond stock, but the stock parts work quite well, especially with 14" wheels. I believe your current booster with new master will be OK with OE front calipers which have generous piston area. Some aftermarket calipers have smaller piston area and need more boost pressure. http://www.moparaction.com/tech/archive/disc-main.htmlhttp://www.doctordiff.com/brakes/
[Re: MikeyT]
#1817571
05/03/15 10:46 AM
05/03/15 10:46 AM
MikeyT
Watertown, WI
Thank you Ahy! Those are very informative links.
Mike
