318 connecting rod question #181720
01/02/09 02:12 PM
01/02/09 02:12 PM
NC
alpha727 Offline OP
alpha727  Offline OP
NC
I am planning on building the exact same 318-400hp junkyard jewel that Hot Rod built a few years back. link: http://www.hotrod.com/howto/113_0304_318_small_block_build/index.html
I had also read another 318 build that mopar muscle built using off the shelf parts and magnum heads. In the article from the mopar muscle build they mentioned that the early rods from the 318 weren't as strong as the later rods. I've read How to Hot Rod Mopar small blocks and it never mentions that the rods from the early 318's are weaker but it does mention that the early rods have full floating piston pins which I would rather have if the strength between the early rods and later rods are equal. As you have probably figured out I'm too cheap to buy anything aftermarket otherwise I'd probably be building a 340. Any help would be greatly appreciated.
Re: 318 connecting rod question [Re: alpha727] #181721
01/02/09 02:29 PM
01/02/09 02:29 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
The early 318 rods were slightly lighter but I know several guys running them on the dirt track because they are a little lighter.
Re: 318 connecting rod question [Re: MoparforLife] #181722
01/02/09 03:13 PM
01/02/09 03:13 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
I have a set of (7) floating pin 318 rods, casting #2406782. I bought them as spares, hence the incomplete set........they are clean, and in great shape. The rod 3rd from the left is copper coated, that's not rust. Let me know if you are interested, just PM me.
Re: 318 connecting rod question [Re: MoparforLife] #181723
01/02/09 03:31 PM
01/02/09 03:31 PM
NC
alpha727 Offline OP
alpha727  Offline OP
NC
have the dirt track guys ever broken a rod with the floating pin type?
Re: 318 connecting rod question [Re: alpha727] #181724
01/02/09 03:33 PM
01/02/09 03:33 PM
Upper Midwest
Upper Midwest
Not rreally that you would attribute to using the lighter rods. Hell they can break anything.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: 318 connecting rod question [Re: alpha727] #181725
01/02/09 03:35 PM
01/02/09 03:35 PM
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
There is always that possiblity, I guess the question you really need to ask yourself is how much you want to abuse this little engine? If you are really trying to get big block power out of it, then maybe you should build a big block instead..........
Re: 318 connecting rod question [Re: 4BBodies] #181726
01/02/09 03:48 PM
01/02/09 03:48 PM
NC
alpha727 Offline OP
alpha727  Offline OP
NC
Not really interested in big blocks. I like the idea of building a fast car for practically nothing. That's why I've chosen the 318 they're practically giving them away I'm just trying to make sure that I'm not going to throw a rod because I chose the floating pin rods over the pressed pin rods.
Re: 318 connecting rod question [Re: alpha727] #181727
01/02/09 04:23 PM
01/02/09 04:23 PM
Upper Midwest
Upper Midwest
The rods will be the least of your worries. You won't put the abuse on it in years that they do in 1 night. They ain't pushing 318 size pistons around either. They are using 360's.
Re: 318 connecting rod question [Re: alpha727] #181728
01/02/09 05:26 PM
01/02/09 05:26 PM
not yet I'm running them up to 6500 but I had the big end meticulously rebuilt ARP bolts/nuts shot peened them, polished the stress risers out & a perfect balance and oiling mods. that was an interesting article 400 hp with a stock short block(exc cam) & ported 302 heads. I think steve Dulcich is a pretty good porter.
