318 connecting rod question
#181720
01/02/09 02:12 PM
01/02/09 02:12 PM
Posts: 133 NC
alpha727
NC
I am planning on building the exact same 318-400hp junkyard jewel that Hot Rod built a few years back. link: http://www.hotrod.com/howto/113_0304_318_small_block_build/index.htmlI had also read another 318 build that mopar muscle built using off the shelf parts and magnum heads. In the article from the mopar muscle build they mentioned that the early rods from the 318 weren't as strong as the later rods. I've read How to Hot Rod Mopar small blocks and it never mentions that the rods from the early 318's are weaker but it does mention that the early rods have full floating piston pins which I would rather have if the strength between the early rods and later rods are equal. As you have probably figured out I'm too cheap to buy anything aftermarket otherwise I'd probably be building a 340. Any help would be greatly appreciated.
Re: 318 connecting rod question
[Re: alpha727]
#181724
01/02/09 03:33 PM
01/02/09 03:33 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Not rreally that you would attribute to using the lighter rods. Hell they can break anything.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
