No 2nd gear with manual valvebody
#1815670
04/30/15 06:31 PM
04/30/15 06:31 PM
Posts: 4,689 Wichita
GY3
Wichita
Forward pattern Cheetah.
Took the car to have it aligned and the idiot that INSISTED on driving it into the bay kept trying to use 3rd gear to move it. Get in the car to drive home and NO 2nd gear?!!
1st and 3rd work fine.
Accumulator cocked in the bore?
Re: No 2nd gear with manual valvebody
[Re: qwkmopardan]
#1815727
04/30/15 07:39 PM
04/30/15 07:39 PM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
I did have a 2nd gear band snap , just driving down the road . Trans out for that Good luck
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#1815744
04/30/15 08:00 PM
04/30/15 08:00 PM
GY3
Wichita
Thanks for the replies. The jam nut backed off and let the piece that goes between the adjuster screw and the band fall out...
[Re: tex013]
#1815979
05/01/15 12:44 AM
05/01/15 12:44 AM
Posts: 1,491 Oologah, Oklahoma
Big Squeeze
Oologah, Oklahoma
Tex You can actually buy a "slip" or "snap" band to replace that band while the Trans is still in the car...just cut one end off the old band to slip it out...I install them into 2006 Dodge trucks all the time...
If you can't handle the truth, you're living a lie.......
[Re: Big Squeeze]
#1816016
05/01/15 01:17 AM
05/01/15 01:17 AM
tex013
Sydney,Australia
Darn , haven't seen that down here . thanks for the heads up - maybe not best for a bracket raced trans ? been 30 odd years since I worked in a auto only shop
Tex
