No 2nd gear with manual valvebody #1815670
04/30/15 06:31 PM
04/30/15 06:31 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Forward pattern Cheetah.
Took the car to have it aligned and the idiot that INSISTED on driving it into the bay kept trying to use 3rd gear to move it. Get in the car to drive home and NO 2nd gear?!!
1st and 3rd work fine.
Accumulator cocked in the bore?
'63 Dodge 330
11.19 @ 121 mph
Re: No 2nd gear with manual valvebody [Re: GY3] #1815686
04/30/15 06:40 PM
04/30/15 06:40 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Either the lever or the link broke. Most likely the link between the band and the lever. Easy fix with trans in car.
Re: No 2nd gear with manual valvebody [Re: qwkmopardan] #1815727
04/30/15 07:39 PM
04/30/15 07:39 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I did have a 2nd gear band snap , just driving down the road . Trans out for that
Good luck
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: No 2nd gear with manual valvebody [Re: tex013] #1815744
04/30/15 08:00 PM
04/30/15 08:00 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Thanks for the replies. The jam nut backed off and let the piece that goes between the adjuster screw and the band fall out...
'63 Dodge 330
11.19 @ 121 mph
Re: No 2nd gear with manual valvebody [Re: tex013] #1815979
05/01/15 12:44 AM
05/01/15 12:44 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Good luck
Tex
You can actually buy a "slip" or "snap" band to replace that band while the Trans is still in the car...just cut one end off the old band to slip it out...I install them into 2006 Dodge trucks all the time...
If you can't handle the truth, you're living a lie.......
Re: No 2nd gear with manual valvebody [Re: Big Squeeze] #1816016
05/01/15 01:17 AM
05/01/15 01:17 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Darn , haven't seen that down here .
thanks for the heads up - maybe not best for a bracket raced trans ?
been 30 odd years since I worked in a auto only shop
Tex
New best MPH 130.32
