Re: My Gen III Hemi A-body build.
[Re: 72Swinger]
#1812076
04/26/15 01:14 AM
04/26/15 01:14 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Thanks Tom, So today I got the radiator and hoses, driveshaft, trans filled, power steering cooler mounted, PS lines all on, PS fluid in and antifreeze all done. Decided to put my battery on the passenger floor board and "temporarily wire" the EFI,starter and gauges. So I spin the starter and watch the oil pressure gauge, it bounces to 20 psi and back to 0. WTF? So I get out and see a puddle forming under the front of the engine WTFFFMOFO??? Its dripping from the Derale remote filter adapter, the alternator, and the oil pressure sender. I immediately start cussing the Derale adapter because that really looks like where it is originating from.
So im staring up at it all from my creeper with a light telling Murphy to go away, and then the light shines up high enough I can see a hole on the front of the block wet with oil. WTF? Well long story short, unknown to me is a oil galley plug hole on the FRONT OUTSIDE of the block with no plug. Didn't even know it existed, I didn't remove it and don't remember noticing it ever. I figured out it is 1/8" pipe and ran to Menards of all places and found a brass plug for it, reinstalled the alternator and belt, jumper wired everything again and VIOLA 50psi while cranking! Heart attack diverted. Tomorrow I plan to hook up some fuel to her and make that video of it idling. Murphy be damned....
Mopar to the bone!!!
[Re: 72Swinger]
#1812103
04/26/15 02:05 AM
04/26/15 02:05 AM
72Swinger
Nebraska
Here is the culprit of my near coronary...
[Re: 72Swinger]
#1812249
04/26/15 12:26 PM
04/26/15 12:26 PM
72Swinger
Nebraska
Mine was never there it was in the bottom outside 3/8" pipe port.
[Re: 72Swinger]
#1814951
04/29/15 11:30 PM
04/29/15 11:30 PM
Posts: 751 Saint Peters, MO
Brian
Saint Peters, MO
Congratulations, I hope I'm about 4 months behind you
1971 6.1 Gen III Hemi Duster
[Re: 72Swinger]
#1814955
04/29/15 11:33 PM
04/29/15 11:33 PM
72Swinger
Nebraska
Thanks, if you got yours running in a year, you would be about 8 months ahead of me still lol!
[Re: 6packattk]
#1816011
05/01/15 01:11 AM
05/01/15 01:11 AM
72Swinger
Nebraska
Thanks for the on my birthday initial fire up vid.Wont be long now till test with a drive.You did good my brother You are welcome broheem!
[Re: 72Swinger]
#1834028
05/25/15 06:00 PM
05/25/15 06:00 PM
72Swinger
Nebraska
Couple updates: New swaybar clamps and 1.18" T-bars are in Oil cooler back on, it JUST fits Its looking like a car again Aftermarket tilt column adapted Dash %90 complete.
[Re: 72Swinger]
#1844753
06/09/15 01:52 AM
06/09/15 01:52 AM
72Swinger
Nebraska
Went on ring seating hellride today. Made about 10 hard pulls with the autotune feature on the MS3 doing its thing. Still struggling to get a nice surge free idle lower that 11-1200 rpm. Drove up and over hills with a constant temp of about 205 with one fan only working. The thing really starts to come alive at about 5000 rpm is all im gonna say. Only had nerve for 6000 rpm today. Dash gauge was in the 11.6-12.2 under full throttle/load. Honestly doing this with a laptop on your lap that the sun makes almost impossible to see, reading the speedo,tach and afr gauge with goggles on because there is no windshield is not exactly ideal. Probably going to drop the oil and cut open filter and put in some 5w30 Valvoline I have sitting in the corner for another 500 miles.
