440 rods,low cost but good ones #1813490
04/27/15 11:08 PM
04/27/15 11:08 PM
Pa. U.S.A.
moparborn Offline OP
Pa. U.S.A.
What rods are available for a 6.76 rod,2.375-2.75-1.094
at a good price but not cheapies?
I have late model stockers,I could send them out to be worked over but I do not think they would hold up in a stroker.
Re: 440 rods,low cost but good ones [Re: moparborn] #1813627
04/28/15 01:36 AM
04/28/15 01:36 AM
Cab_Burge Online work
Cab_Burge  Online Work
Call Tom Molnar at 616-940-4640 and see what he offers and then try Scat, Ohio Crankshaft CO. and then Summit and Jegs. I'm sure Summit handles and sells the Scat line as well as several other companys that sell forged steel H beam rods for Mopar BB scope upI've used several different brnads of imported Chineze rods for BB Chevy in BB Mopar stroker motors, no problems so far shruggy
Re: 440 rods,low cost but good ones [Re: moparborn] #1814347
04/29/15 12:52 AM
04/29/15 12:52 AM
Socal
littleVAL Offline
littleVAL  Offline
Socal
Call wiseco and see if there clearance ones are still available they where under $250 for the h beam ones when I bought my small block ones a few months back also stroker crank for $399 I was real tempted to redo 73 truck motor with such good deals
Re: 440 rods,low cost but good ones [Re: moparborn] #1814622
04/29/15 03:39 PM
04/29/15 03:39 PM
Carson City, NV
440sourcedotcom Offline
Carson City, NV
Depends if you are looking for a floating or pressed pin. If you are using a pressed pin, we carry a nice set that uses 7/16" capscrews and is much stronger than the factory option, at only $249/set with free freight.
See them here:
http://store.440source.com/Connecting-Rods-RB-with-Capscrew-bolts-Set-of-8/productinfo/200-1132/
Re: 440 rods,low cost but good ones [Re: 440sourcedotcom] #1814673
04/29/15 05:23 PM
04/29/15 05:23 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Not directed at ANYONE, but just pointing out that "cheap" rods only stay "cheap" when they don't cost you additional $$$ to have them corrected for poor quality control during machining.
Re: 440 rods,low cost but good ones [Re: BradH] #1814681
04/29/15 05:30 PM
04/29/15 05:30 PM
an8sec70cuda Offline
iagree All of the cheaper rods need to be checked thoroughly by your machinist. All brands of rods should be checked regardless, but the lower priced rods like Eagle, Scat, etc., will most likely need to be resized right out of the box due to poor machining at the factory.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 440 rods,low cost but good ones [Re: moparborn] #1814739
04/29/15 07:27 PM
04/29/15 07:27 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
"LY"
Re: 440 rods,low cost but good ones [Re: J_BODY] #1814766
04/29/15 08:01 PM
04/29/15 08:01 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
Originally Posted By J_BODY
"LY"
Seen many 600 Hp BB with old LYs that lived for many years.
Re: 440 rods,low cost but good ones [Re: moparborn] #1814947
04/29/15 11:25 PM
04/29/15 11:25 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Scats are 425 and are available with the big pin
Re: 440 rods,low cost but good ones [Re: moparborn] #1814954
04/29/15 11:33 PM
04/29/15 11:33 PM
Pa. U.S.A.
Pa. U.S.A.
Full floating would be nice and convenient,but pressed will be fine.
Thanks for the input guys.
Re: 440 rods,low cost but good ones [Re: 440sourcedotcom] #1815141
04/30/15 02:59 AM
04/30/15 02:59 AM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
The 440 source ones look pretty good, anyone know what is the weight on them?
Re: 440 rods,low cost but good ones [Re: J_BODY] #1815153
04/30/15 03:14 AM
04/30/15 03:14 AM
BradH Offline
BradH  Offline
"LY"
As long as they've been reconditioned with GOOD rod bolts. Otherwise, they're a lit fuse.
Re: 440 rods,low cost but good ones [Re: an8sec70cuda] #1815166
04/30/15 03:44 AM
04/30/15 03:44 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
They ALL need to be sized (not resized) OOTB. Saying it's poor QC is a misconception.
They all come honed so they can fit the smallest .990 pin on the market. There are several .990 pins on the market none of them are .990".
If the smallest brand pin is say .989" and the biggest is .991", all it takes is a rod hone to make one part# cover all .990 pins.
Kevin
Re: 440 rods,low cost but good ones [Re: Twostick] #1815366
04/30/15 01:20 PM
04/30/15 01:20 PM
BradH Offline
BradH  Offline
Kevin
The big ends aren't even round on some of the "budget" rods, not just that the pin may be tight. So, it's not incorrect to say that there may be resizing involved, too.
Re: 440 rods,low cost but good ones [Re: BradH] #1815411
04/30/15 02:06 PM
04/30/15 02:06 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Agreed but when people are complaining about cheap Chinese junk it is usually because they had to open up the small end.
I think the laws of mass production dictate that some rods will occasionally have big ends out of spec.
Kevin
Re: 440 rods,low cost but good ones [Re: moparborn] #1815424
04/30/15 02:24 PM
04/30/15 02:24 PM
My experience is the big end is the issue and needs to be RESIZED. The mating surfaces of the cap and the rod are cut tapered and puts the bolt in a bind when torqued. This causes the I.D. to vary .001" or more just by loosening and retorquing the bolts. Throw a straight edge across the mating surface and you'll see daylight on the inside.
I've personally seen this on Eagle and Manley H beams.
I agree w/ what BradH said also...even on the ones that are cut straight, the big ends often aren't round.
CHIP
