493" how much carb cfm needed?? #181313
01/02/09 08:27 AM
01/02/09 08:27 AM
Ohio
fiddlestix Offline OP
Ohio
I'm building a 493 (440) stroker to put in my 3500lb Challenger. 11:1 compression stage 3 Eddy RPM's .615 lift solid roller with .263 @ .050" with a home ported Holley Street dominator intake 3500 stall with 4:10 gears. This will be mostly street driven. My question is how much actual carb cfm will it take to support this engine using a 4150 base? thanks for any advice.
Re: 493" how much carb cfm needed?? [Re: fiddlestix] #181314
01/02/09 08:44 AM
01/02/09 08:44 AM
Colorado
506RR Offline
506RR  Offline
Colorado
Since you will be street driving it, I would go with a 950 cfm.
Re: 493" how much carb cfm needed?? [Re: 506RR] #181315
01/02/09 08:48 AM
01/02/09 08:48 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We like the 1050 Holly HP for all our 470" and up engines.
Re: 493" how much carb cfm needed?? [Re: 506RR] #181316
01/02/09 08:52 AM
01/02/09 08:52 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
The 950HP worked great on my 451, although not quite as good as the 1050 Dominator, only by a couple hundredths and 2 MPH.
I would probably run a 1050 on your car but the 950 would be better on the street as already mentioned.
Does anybody here run a 1050 4150 carb? I've always wondered how they run compared to a Dommy on the street and strip.
Re: 493" how much carb cfm needed?? [Re: ProSport] #181317
01/02/09 09:18 AM
01/02/09 09:18 AM
Ohio
Ohio
The reason I posted actual cfm is I was wondering how a stock 950-1000 Holley or proform flow as compared to a 850 that has been cnc'd and professionally worked over. I have a chance to buy an 850 and was wondering if it will be big enough.
Re: 493" how much carb cfm needed?? [Re: fiddlestix] #181318
01/02/09 09:20 AM
01/02/09 09:20 AM
Central NC
gch Offline
gch  Offline
Central NC
It will work.You may give up a little power to a 1000 or larger.
If yours has been worked it may flow more than 850.
Re: 493" how much carb cfm needed?? [Re: fiddlestix] #181319
01/02/09 10:17 AM
01/02/09 10:17 AM
NC
440Jim Offline
440Jim  Offline
NC
As stated by others, the Dominator will be faster on the track. But I like the 4150 for the street.
The hard part is knowing what every companies carb actually flows (using the same standard). And I don't have that info. All 950's don't flow the same, and they don't even have the same venturi size! They all have 1.75" baseplate/butterfly, but Holley's venturi is 1.375, Proform 1.45" (their 850 is 1.40"), and who knows what custom carb shops are using in their 950, or 1000 cfm. The old style mod of machining off the choke horn from the main body is not as good as the more modern HP main bodies cast without the choke horn and a better transition.
My recommendation is to call ProSystems and have them setup one of their 950 or 1000 hp carbs.
Re: 493" how much carb cfm needed?? [Re: 440Jim] #181320
01/02/09 10:22 AM
01/02/09 10:22 AM
Get-X Offline
Get-X  Offline
If you're going to use a 4150, make sure it's based off of the 850DP, like a 1000HP. As the others have already mentioned, the 1050 dommy will out perform the 4150 at the track and is still streetable.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: 493" how much carb cfm needed?? [Re: fiddlestix] #181321
01/02/09 11:45 AM
01/02/09 11:45 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
my old setup was just like that in my challenger I ran a solid roller with a little less dur but I had more lift that you.. I ran a TM7 with the 4500 adapter and a custom BIGS 1050 Dominator carb.. runs great on the street...
Mopar Performance
Re: 493" how much carb cfm needed?? [Re: moparniac] #181322
01/02/09 12:11 PM
01/02/09 12:11 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I like the 1000hp on most 500's.
I run a Pro-systems 1000HP 4150 on my 517 that runs a Dommy 3 circuit metering block and it is FANTASTIC on the street. I've been giving serious thought to putting a big 1100+ Dommy on it but I don't know if the modest gains are worth the added cost....I think my days of chasing the last .05 of ET days are winding down......you can see more variation in performance just in the weather on any given day.
Put the car on the Dyno and you may quickly see if the induction is really laying it down....but with Eddies and a Sreet Dominator I don't think you'll need anything more than a 1000HP.....I ran the same carb on my SD topped 508 jetted down a tad. Dyno time is relatively cheap for the wealth of knowledge about your combination you can get from it.
WIZE
In Car:
