Limitations of stock rockers/rocker shaft in performance aps #1812379
04/26/15 04:39 PM
04/26/15 04:39 PM
Tacoma, Washington USA
Adam71Charger Offline OP
What are the limitations of the stock rocker shafts/arms? RPM limits, Lift limits?
Re: Limitations of stock rockers/rocker shaft in performance aps [Re: Adam71Charger] #1812425
04/26/15 06:15 PM
04/26/15 06:15 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
440 292 .501 Comp Magnum 5800 rpm shift point. owned for 20 + years , driven often. Stock stamped rockers. One rocker failure about 15 years ago. The holes do elongate over time though. They may not look like much,But I definitely have more faith in them than an entry level(cheap) roller rocker.
Re: Limitations of stock rockers/rocker shaft in performance aps [Re: Adam71Charger] #1812475
04/26/15 07:14 PM
04/26/15 07:14 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Depends on exactly which "stock" rocker setup you are referring to.
LA adjustable ones?
LA stamped?
B/RB stamped? early or late style?
B/RB adjustables?
Don't be the exception.
Re: Limitations of stock rockers/rocker shaft in performance aps [Re: Supercuda] #1812654
04/26/15 11:22 PM
04/26/15 11:22 PM
Stamped from 1977 452 heads. Thinking about using the heads on a basic rebuild engine.
Re: Limitations of stock rockers/rocker shaft in performance aps [Re: Adam71Charger] #1812684
04/26/15 11:43 PM
04/26/15 11:43 PM
IN
ahy Offline
ahy  Offline
IN
Rule of thumb, .5" lift. They have been used with 509 cams successfully but can fail with heavy springs/frequent high RPM in that application (>6000 RPM?).
Re: Limitations of stock rockers/rocker shaft in performance aps [Re: Adam71Charger] #1812685
04/26/15 11:43 PM
04/26/15 11:43 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I remember some online Mopar magazine article where they used stamped rockers (probably aftermarket HD versions) on a cam around .530 lift.
I have used the HD variety for years with a .509 cam and eddy heads and springs. No problems at all, not that I put a lot of miles on it, but I don't think I'm pushing the limits with them either.
Re: Limitations of stock rockers/rocker shaft in performance aps [Re: Adam71Charger] #1812898
04/27/15 09:53 AM
04/27/15 09:53 AM
A certified culture free zone.
74RALLYE Offline
74RALLYE  Offline
I've had 2 Harland Sharp roller tip rockers fail on a professionally built street engine. I'm not exceeding 500hp, so the next 440 get stock rockers.
Re: Limitations of stock rockers/rocker shaft in performance aps [Re: Adam71Charger] #1812963
04/27/15 12:22 PM
04/27/15 12:22 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Early B/RB stamped units where known to put a pushrod thru the cup in spirited use, so Chrysler stepped up to a thicker metal to fix it. 77's should be that thicker stuff. I believe all the aftermarket stuff available today is also the thicker stuff.
Re: Limitations of stock rockers/rocker shaft in performance aps [Re: Adam71Charger] #1813095
04/27/15 03:26 PM
04/27/15 03:26 PM
AndyF Offline
AndyF  Offline
Yeah, a pushrod will poke thru the stamped rocker arms pretty quickly once the spring pressure gets much above stock levels. I've seen it happen a few times on "budget" engines. My old 1 ton truck came home on a flatbed once after a rocker arm failed in the 440. That engine had a very mild 440+6 cam in it with stock type springs.
Re: Limitations of stock rockers/rocker shaft in performance aps [Re: Adam71Charger] #1813423
04/27/15 10:15 PM
04/27/15 10:15 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I ran a street hemi grind in my 413 with stock stamped rockers and the proper springs with zero issues. YMMV, but I know I had the later and thicker ones. Never put a came with .500" or more lift in my engines anyway.
