Re: Limitations of stock rockers/rocker shaft in performance aps
[Re: Adam71Charger]
#1812475
04/26/15 07:14 PM
04/26/15 07:14 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Depends on exactly which "stock" rocker setup you are referring to.
LA adjustable ones?
LA stamped?
B/RB stamped? early or late style?
B/RB adjustables?
[Re: Adam71Charger]
#1812963
04/27/15 12:22 PM
04/27/15 12:22 PM
Supercuda
About to go away
About to go away
up yours
Early B/RB stamped units where known to put a pushrod thru the cup in spirited use, so Chrysler stepped up to a thicker metal to fix it. 77's should be that thicker stuff. I believe all the aftermarket stuff available today is also the thicker stuff.
[Re: Adam71Charger]
#1813423
04/27/15 10:15 PM
04/27/15 10:15 PM
Supercuda
About to go away
About to go away
up yours
I ran a street hemi grind in my 413 with stock stamped rockers and the proper springs with zero issues. YMMV, but I know I had the later and thicker ones. Never put a came with .500" or more lift in my engines anyway.
