engine oil #1811918
04/25/15 10:31 PM
04/25/15 10:31 PM
st. Louis Mo.
dartphil Offline OP
dartphil  Offline OP
st. Louis Mo.
What kind of oil are guys running with solid cams?
Re: engine oil [Re: dartphil] #1811926
04/25/15 10:41 PM
04/25/15 10:41 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I use amsoil. Dominator 15/50. Brad Penn 20/50 if I'm low on cash.
Re: engine oil [Re: mopar dave] #1811937
04/25/15 10:51 PM
04/25/15 10:51 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Brad Penn 20-50..... 'cause I'm always low on cash laugh2
Re: engine oil [Re: dartphil] #1811974
04/25/15 11:33 PM
04/25/15 11:33 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Brad Penn 10-30
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: engine oil [Re: pittsburghracer] #1812071
04/26/15 01:03 AM
04/26/15 01:03 AM
IN
ahy Offline
ahy  Offline
IN
Rotella T 15W40 from Walmart + STP. Has worked great for 15k miles including some track time.
Re: engine oil [Re: dartphil] #1812072
04/26/15 01:05 AM
04/26/15 01:05 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Royal Purple 20/50 in mine since run in , motor been running since 2007. Brad Penn run in oil and Brad Penn 40 (?) Straight mineral for first 600 miles.
Will only warrant cam/engine with these 2 oils .
Have heard good results with Lucas oils , in roller cam motor .
Oil choice is like beer , lots of flavours just got to find 1 you like .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: engine oil [Re: dartphil] #1812171
04/26/15 10:07 AM
04/26/15 10:07 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Brad Penn 10w30
5.53 @ 125 1/8th on the launch control..more left in her!
Re: engine oil [Re: Eric] #1812197
04/26/15 11:05 AM
04/26/15 11:05 AM
st. Louis Mo.
dartphil Offline OP
dartphil  Offline OP
st. Louis Mo.
thanks guys,looks like brad penn is the favorite
Re: engine oil [Re: dartphil] #1812241
04/26/15 12:15 PM
04/26/15 12:15 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Rotella
Re: engine oil [Re: dartphil] #1812252
04/26/15 12:31 PM
04/26/15 12:31 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Brad Penn UNLESS It is E85. They don't play well together.
Re: engine oil [Re: dartphil] #1812294
04/26/15 01:44 PM
04/26/15 01:44 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Mobil 1 15w-50 synthetic since beginning. Hemi grind hydraulic, .590 purple shaft solid, Herbert roller. Never let me down.
[image][/image]
Re: engine oil [Re: sgcuda] #1812305
04/26/15 02:12 PM
04/26/15 02:12 PM
SoCal
Brian Hafliger Offline
SoCal
We use and recommend Torco TR-1
Brian Hafliger
Re: engine oil [Re: roadhazard] #1812487
04/26/15 07:30 PM
04/26/15 07:30 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
VR 1 30 WT. 850 runs and still going strong
Re: engine oil [Re: dartphil] #1812494
04/26/15 07:33 PM
04/26/15 07:33 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
15w40 Rotella
Nautilus Racing-
Re: engine oil [Re: Chris2581] #1812527
04/26/15 08:50 PM
04/26/15 08:50 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Royal Purple 10w40, best oil i've used to date & i've been thru a lot of different brands including Brad Penn.
Re: engine oil [Re: Al_Alguire] #1812532
04/26/15 08:58 PM
04/26/15 08:58 PM
SC304 Offline
SC304  Offline
Al,
May I ask what it is that " they don't play we'll together" means and what do you run with E85 for oil?
Re: engine oil [Re: dartphil] #1812744
04/27/15 12:21 AM
04/27/15 12:21 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
VR1 10w/30 . But I have a lot of left over 20/50 that I used on a car I sold so I may go with 3q 10/30 and 2q 20/50 to get close to a 15/40
Re: engine oil [Re: dartphil] #1812774
04/27/15 12:43 AM
04/27/15 12:43 AM
Az
Crizila Offline
Crizila  Offline
Az
Royal Purple 10-40 race oil. Slickern snot!
Fastest 300
Re: engine oil [Re: Crizila] #1812798
04/27/15 01:03 AM
04/27/15 01:03 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I've been running Lucas "HotRod" 10w-30 with a zinc additive for a few years now.
Re: engine oil [Re: dartphil] #1812933
04/27/15 11:03 AM
04/27/15 11:03 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
Driven 10w-30 conventional oil in the Stocker and Driven 5w-20 synthetic in the SS motor. Run a 10w-30 synthetic in the bracket roller motors. I am a Driven oil dealer (Joe Gibbs) if anyone needs any.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
