Re: engine oil
[Re: dartphil]
#1812072
04/26/15 01:05 AM
04/26/15 01:05 AM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
Royal Purple 20/50 in mine since run in , motor been running since 2007. Brad Penn run in oil and Brad Penn 40 (?) Straight mineral for first 600 miles. Will only warrant cam/engine with these 2 oils . Have heard good results with Lucas oils , in roller cam motor . Oil choice is like beer , lots of flavours just got to find 1 you like .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: engine oil
[Re: dartphil]
#1812241
04/26/15 12:15 PM
04/26/15 12:15 PM
Quicktree
Re: engine oil
[Re: dartphil]
#1812252
04/26/15 12:31 PM
04/26/15 12:31 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
Brad Penn UNLESS It is E85. They don't play well together.
Re: engine oil
[Re: sgcuda]
#1812305
04/26/15 02:12 PM
04/26/15 02:12 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
We use and recommend Torco TR-1
Brian Hafliger
Re: engine oil
[Re: dartphil]
#1812774
04/27/15 12:43 AM
04/27/15 12:43 AM
Posts: 7,506 Az
Crizila
Az
Royal Purple 10-40 race oil. Slickern snot!
Fastest 300
Re: engine oil
[Re: Crizila]
#1812798
04/27/15 01:03 AM
04/27/15 01:03 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I've been running Lucas "HotRod" 10w-30 with a zinc additive for a few years now.
Re: engine oil
[Re: dartphil]
#1812933
04/27/15 11:03 AM
04/27/15 11:03 AM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
Driven 10w-30 conventional oil in the Stocker and Driven 5w-20 synthetic in the SS motor. Run a 10w-30 synthetic in the bracket roller motors. I am a Driven oil dealer (Joe Gibbs) if anyone needs any.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
