any one install a timing belt 4.0 pacifica #1812000
04/25/15 11:58 PM
04/25/15 11:58 PM
Alton, IL
Dakota_Don Offline OP
Alton, IL
Hello, anyone install a belt kit on a 4.0 pacifica or a 3.5.. whats the trick on getting the belt around the water pump tight with both gears in line.. I have tried everything and this thin looks so simple yet its kicking my butt..
thanks for the tips..
Re: any one install a timing belt 4.0 pacifica [Re: Dakota_Don] #1812153
04/26/15 09:29 AM
04/26/15 09:29 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Are you holding the belt to the gears? You can use small vice grips.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: any one install a timing belt 4.0 pacifica [Re: RMCHRGR] #1812228
04/26/15 11:58 AM
04/26/15 11:58 AM
Alton, IL
Alton, IL
yes sir I am..
Re: any one install a timing belt 4.0 pacifica [Re: Dakota_Don] #1812258
04/26/15 12:38 PM
04/26/15 12:38 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Originally Posted By Dakota_Don
yes sir I am..
There's a pin in the tensioner, right? Did you retract the tensioner and hold it with the pin? As long as the belt is held on, then put the tensioner in and release the pin - it should hold the tension on the belt.
Not sure what else to tell ya. Maybe Guitar Jones will chime in.
'71 Duster
'72 Challenger
'17 Ram 1500
