Seeking Fiberglass trunk bracket and pin location opinions #1805072
04/16/15 05:22 PM
04/16/15 05:22 PM
Indiana
Chryco69 Offline OP
Missing my hose
Chryco69  Offline OP
Missing my hose
Indiana
I own a stock 1968 Dodge Dart 270 that I am converting into a 1968 Dodge Dart Hemi Super Stock.
I was given a fiberglass lift off trunk lid for free. ***Let it be noted that I am aware that the 1968 Dodge Dart Hemi Super Stock's did not come equipped from the factory with fiberglass trunk lids***
I am trying to keep the outside appearance of the car very traditional as if it was being altered in the early 1970's. I plan on using the exact same factory pin kits that were used to hold down the fiberglass Hemi hoods so that they match and also look traditional.
If you or someone that you know have already done this, can you please share your knowledge and post pictures if possible?
Thanks!
Re: Seeking Fiberglass trunk bracket and pin location opinions [Re: Chryco69] #1811922
04/25/15 10:36 PM
04/25/15 10:36 PM
Indiana
Chryco69 Offline OP
Missing my hose
Chryco69  Offline OP
Missing my hose
Indiana
Anyone?
Re: Seeking Fiberglass trunk bracket and pin location opinions [Re: Chryco69] #1811949
04/25/15 11:10 PM
04/25/15 11:10 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Thanks!
Let it be noted..... ONLY on Moparts would you have to make this disclaimer haha stirthepot
I really don't have much to add concerning the Dart body. However, I would think 4 would be sufficient depending on the under-structure of the lid.
Guess my best suggestion would be to lay out scuff plates on the deck lid where they "look good" to YOU and see what would be involved for locating the pins....
Re: Seeking Fiberglass trunk bracket and pin location opinions [Re: roadhazard] #1812021
04/26/15 12:10 AM
04/26/15 12:10 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
If I hadn't sold my M-Code Dart to slax69gts I could take pictures. Maybe PM him? It had 4 hood pins holding down the fiberglass deck lid.
JB Rhinehart, Realist
A-Body's RULE!
Re: Seeking Fiberglass trunk bracket and pin location opinions [Re: Chryco69] #1812048
04/26/15 12:33 AM
04/26/15 12:33 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
4 pins are plenty. I only have 4 on the hood of my 64 Belvedere. It hasn't come off at 147. I would fab some simple plates and attach them to the bottom of the trunk gutter channel. Something like this.
Doug
