Identify this part #1810090
04/23/15 12:50 PM
04/23/15 12:50 PM
Hinckley, Ohio
KWF340 Offline OP
KWF340  Offline OP
Hinckley, Ohio
I'm finally reassembling my '70 Charger, and for some reason I don't have a picture (prior to disassembly) of the part below. I think it is related to the AC/heater box (possibly the evaporator). Anyone know what it is/where it goes?
1968 Charger R/T, 440 Auto, GG1;
1969 Super Bee, 383, 4-speed, T5;
1969.5 Road Runner, 440-6, 4-speed, 96;
1970 Duster 340, 4-speed, EV2;
1970 Charger R/T SE, 440 (496), Auto, EB3;
1970 Dart Swinger 340 (416), 4-speed, EV2;
1970 Corvette coupe, LS5, 4-speed, Daytona yellow;
2000 Corvette coupe, LS1, 6-speed, Twin Turbo, Torch red.
Re: Identify this part [Re: KWF340] #1810106
04/23/15 01:14 PM
04/23/15 01:14 PM
Kenosha, Wi
GOLDMYN Offline
GOLDMYN  Offline
Kenosha, Wi
yes, ac on the cowl
Semper Fi
Re: Identify this part [Re: GOLDMYN] #1810109
04/23/15 01:18 PM
04/23/15 01:18 PM
Kenosha, Wi
GOLDMYN Offline
GOLDMYN  Offline
Kenosha, Wi
here you are
Semper Fi
Re: Identify this part [Re: GOLDMYN] #1810143
04/23/15 01:50 PM
04/23/15 01:50 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
but is it used on a '70 Charger (b-body)? work
Re: Identify this part [Re: KWF340] #1810162
04/23/15 02:24 PM
04/23/15 02:24 PM
Hinckley, Ohio
KWF340 Offline OP
KWF340  Offline OP
Hinckley, Ohio
Thanks - that's what I thought it was for but wasn't sure. On my '70 Charger there is a hole that looks like it would correspond to the bracket. The hole is in a different location from the one in the above pic - more down by the brake line. I'll see if I have a pic.
Edit - pic on my phone - not the best but shows the hole.
Re: Identify this part [Re: 6bblgt] #1811475
04/25/15 12:37 PM
04/25/15 12:37 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Exactly, that part is NOT used on a 70 B body , it's an E body piece.
Re: Identify this part [Re: KWF340] #1811554
04/25/15 02:16 PM
04/25/15 02:16 PM
Kenosha, Wi
GOLDMYN Offline
GOLDMYN  Offline
Kenosha, Wi
Sorry, my application is 1971 Charger, next time I'll just pass.
Semper Fi
Re: Identify this part [Re: KWF340] #1811565
04/25/15 02:28 PM
04/25/15 02:28 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
My 1970 Coronet with AC does not use that bracket.
Re: Identify this part [Re: KWF340] #1811619
04/25/15 03:41 PM
04/25/15 03:41 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
A/C line bracket for 71-4B and 70-4E.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Identify this part [Re: KWF340] #1811623
04/25/15 03:50 PM
04/25/15 03:50 PM
Mass
charge70 Offline
charge70  Offline
Mass
My 70 Charger 500,70 Charger R/T and my brothers 70 Charger R/T all have this bracket on them.Both R/Ts are U-Code cars and the 500 is an N-Code car.Possibly a big block only thing in 70 B-Bodies. John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Identify this part [Re: KWF340] #1811718
04/25/15 05:27 PM
04/25/15 05:27 PM
moparmarks Offline
moparmarks  Offline
After checking I had a 70 Coronet A/C car with it. I don't know if it was a BB or SB. Was just a shell when I got it to cut up.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Identify this part [Re: KWF340] #1811728
04/25/15 05:39 PM
04/25/15 05:39 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I just took another look, no hole on my car for the mounting screw either.
So, possibly an early vs. late thing or small block vs. big block?
Mine is a 318 car, built in St. Louis with 10-1969 on the Mylar door sticker.
Re: Identify this part [Re: moparmarks] #1811786
04/25/15 06:57 PM
04/25/15 06:57 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Do you know if that was an LA "0E" built Coronet? work
Re: Identify this part [Re: KWF340] #1811795
04/25/15 07:06 PM
04/25/15 07:06 PM
moparmarks Offline
moparmarks  Offline
I don't.
Did not have a vin, motor, tags or any of that when I got it from the crusher. Just an empty non rolling shell.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Identify this part [Re: Alaskan_TA] #1811827
04/25/15 08:20 PM
04/25/15 08:20 PM
Mass
charge70 Offline
charge70  Offline
Mass
My brothers R/T is a 12/69 build,my R/T is a 3/70 build and my 500 is a 6/70 build date.All 70 Chargers were built in St.Louis,so it has to be a date and or engine thing.Or possibly lazy line workers? John.
Re: Identify this part [Re: KWF340] #2058499
04/20/16 04:30 PM
04/20/16 04:30 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
I have 1970 Plymouth b-bodies with that bracket also. St. Louis built fall 69 all BB powered.
