which cam for my 440 build.. #1810709
04/24/15 02:23 AM
04/24/15 02:23 AM
USA
JoesMopar Offline OP
USA
I've built a few BB's and SB's over the years and want to try a cam I keep hearing about, good and bad, but was curious if there is something else I could use and get what I'm looking for.
I'd like to try the MP 284/484 cam since I've heard it's a "fender shaker".
This is what I have so far that I plan on using:
440 0.060" over and decked 0.010"
KB 237 pistons ~10:1
Holley 870 Street Avenger
Stealth heads (untouched)
MP ignition
What I plan on getting:
Edelbrock Perf. RPM intake
Headers (no particular size/brand yet)
Stock rockers (possibly adjustable rollers)
I also have a 292/.509 cam and a XE274 cam/lifter kit sitting around.
I used the .509 cam in the 440 I plan on using in a '69 Charger with 3200 stall, 3.55 gears, RPM heads, Super Comp headers, and it thundered. It was a blast to drive.
The car I'm building is a '67 Belvedere II, 3000 stall, 3.55 gears, manual brakes, purely a fun street car. I planned on re-using the 509 cam originally, but I'm thinking of saving it for something else.
I'm looking for a rough idle, but not a dog. From what I read on other threads the stall/gears/CR I'm using shouldn't be a problem with the 484 cam. I'm not sure how rough the XE274 is and not sure if the 509 is too much even though I don't have power anything...it was fine in my Charger but a few things are slightly different.
Is there something else you guys would use in place of the 484 or would the 509 do what I want with the parts I've selected on using?
Re: which cam for my 440 build.. [Re: JoesMopar] #1810900
04/24/15 01:21 PM
04/24/15 01:21 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Use that xe274 and stock rockers. The 274 is pretty close in spec to the 284/484 but is a more modern design. The 274 will still have a nice lumpy idle, but be more tame than the 509. For a 3000 stall 10:1 stealth headed 440 with 3.55 gears in a B-body, the 274 is a very good choice IMO.
If you were to upgrade to roller rockers, I would also upgrade to a solid cam.
Re: which cam for my 440 build.. [Re: JoesMopar] #1811020
04/24/15 04:20 PM
04/24/15 04:20 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The 484 cam is dated but still a good stick for a common street car. A friend and I ran one in his 400 powered 69 RoadRunner with a 727 and 3.23 gears. The cam was happy with a stock converter. It was a good all around piece.
There are more modern cams available but I doubt there will be an appreciable difference on a common street car. The cam will talk a little but it's not going to rattle loose screws off the car.
- Stu Harmon
Re: which cam for my 440 build.. [Re: JoesMopar] #1811087
04/24/15 07:08 PM
04/24/15 07:08 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Mopar 484 cam works real good. I used one on a mild 383 and went 11.60's with it.
Nautilus Racing-
Re: which cam for my 440 build.. [Re: JoesMopar] #1811354
04/25/15 02:54 AM
04/25/15 02:54 AM
USA
USA
I had the XE274 set aside for something else but if it's comparable I might try it. I know the 484 is dated but I am building a "dated" type build...old school.
Re: which cam for my 440 build.. [Re: JoesMopar] #1811401
04/25/15 10:31 AM
04/25/15 10:31 AM
Manitoba, Canada
Manitoba, Canada
Toss it in, you'll be happy!
Re: which cam for my 440 build.. [Re: JoesMopar] #1812253
04/26/15 12:31 PM
04/26/15 12:31 PM
Ontario,Canada
1967GTX440 Offline
1967GTX440  Offline
Ontario,Canada
Just reading your post and I have almost the same set up as you are talking about. It works great when you stand on it from a dead stop and it gets close to 2500 RPM it just pulls like a bear and just keeps pulling.
Re: which cam for my 440 build.. [Re: JoesMopar] #1812937
04/27/15 11:26 AM
04/27/15 11:26 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
"rough" "bumpy" idles are overrated. Nowadays it's best to call a custom cam guy and have him grind one up for your application. Both the 509 and 484 really need more than 3.55's to work well.
Re: which cam for my 440 build.. [Re: Mr.Yuck] #1812985
04/27/15 01:07 PM
04/27/15 01:07 PM
dogdays Offline
dogdays  Offline
I'm with Yuck. Having a lumpy idle on a street car tells me the person is more interested in appearances. Either that or he's too ignorant to make a proper cam selection. Or else the car never gets driven except to the drive-in.
Harsh, maybe? I guess so. But I don't believe one can have fun with a car in daily driving if it can't sit at a stoplight and idle for a while, or if the power comes on at 3000 rpm.
R.
Re: which cam for my 440 build.. [Re: dogdays] #1813769
04/28/15 11:16 AM
04/28/15 11:16 AM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Call Bob Karakashian in Michigan, 248-477-7776!
Admiration For Multiple Carburetor Vehicles...
