what fluid for iron torqueflite? #1809874
04/23/15 12:43 AM
04/23/15 12:43 AM
Mogadore, OH
P
putts000 Offline OP
putts000  Offline OP
P
Mogadore, OH
Finally put my trans back together in the 59 fury. Completely rebuilt with a kit from fatsco. I used some dexron III to presoak everything and as assembly lube. Guys at fastco said all the seals and clutches are made with todays materials so any dyno or synthetic is my choice. Would the latest atf+4 work. Latest dexron? Or stick with the tried and true dexron III?
Thanks, Brian
Re: what fluid for iron torqueflite? [Re: putts000] #1809890
04/23/15 01:07 AM
04/23/15 01:07 AM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Type F. Just a little less friction modifiers, allows for a slighter faster clutch hookup.
Re: what fluid for iron torqueflite? [Re: Pacnorthcuda] #1809895
04/23/15 01:13 AM
04/23/15 01:13 AM
Mogadore, OH
P
putts000 Offline OP
putts000  Offline OP
P
Mogadore, OH
When you say friction modifiers, do these make the fluid grip more or slippery?
Re: what fluid for iron torqueflite? [Re: putts000] #1810005
04/23/15 09:56 AM
04/23/15 09:56 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
slippery
It's Swifty! Swifty, you toad sucker!
Re: what fluid for iron torqueflite? [Re: zrxkawboy] #1810100
04/23/15 01:05 PM
04/23/15 01:05 PM
SW CO
HemiSportFury Offline
SW CO
Considering how much those cast iron TFs weigh I use lighter fluid.
Sorry, just couldn't resist.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: what fluid for iron torqueflite? [Re: putts000] #1810232
04/23/15 04:09 PM
04/23/15 04:09 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Friction modifiers can make the fluid either more slippery or more aggressive...in the case of type F, it's more aggressive.
Re: what fluid for iron torqueflite? [Re: putts000] #1810606
04/23/15 11:57 PM
04/23/15 11:57 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Make sure you read the section(s) in the service manual on Torque converter and bell housing alignment to the transmission, Lest you may waste the trans in short order. Ask me how I know ??
To answer your question, Dexron 1- 2 -3 works fine
Re: what fluid for iron torqueflite? [Re: John_Kunkel] #1810678
04/24/15 01:18 AM
04/24/15 01:18 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
That's because Type F has no FM. A HFM (highly friction modified) fluid like ATF+4, on the other hand, allows much more slippage of friction materials. Dex is somewhere in between.
Re: what fluid for iron torqueflite? [Re: zrxkawboy] #1810987
04/24/15 03:31 PM
04/24/15 03:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Friction modifiers can either increase or decrease the coefficient of friction a fluid has, depends on what the formulator wants.
Re: what fluid for iron torqueflite? [Re: putts000] #1811128
04/24/15 08:10 PM
04/24/15 08:10 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Again, John, see my post above. Type F is "grippy" (less slippage of friction materials) because it has no FM. Dex has a moderate amount, and ATF+4 has a high amount (that's why it's called a HFM ATF). I know of no ATF that uses increased amounts of FM to make it "less slippery". If you can provide any credible evidence of one, I'd be very interested in seeing it.
