Re: what fluid for iron torqueflite?
[Re: putts000]
#1810005
04/23/15 09:56 AM
04/23/15 09:56 AM
Posts: 905 SD
zrxkawboy
SD
When you say friction modifiers, do these make the fluid grip more or slippery? slippery
It's Swifty! Swifty, you toad sucker!
[Re: zrxkawboy]
#1810100
04/23/15 01:05 PM
04/23/15 01:05 PM
Posts: 529 SW CO
HemiSportFury
SW CO
Considering how much those cast iron TFs weigh I use lighter fluid.
Sorry, just couldn't resist.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
[Re: putts000]
#1810232
04/23/15 04:09 PM
04/23/15 04:09 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Friction modifiers can make the fluid either more slippery or more aggressive...in the case of type F, it's more aggressive.
[Re: John_Kunkel]
#1810678
04/24/15 01:18 AM
04/24/15 01:18 AM
Posts: 905 SD
zrxkawboy
SD
That's because Type F has no FM. A HFM (highly friction modified) fluid like ATF+4, on the other hand, allows much more slippage of friction materials. Dex is somewhere in between.
[Re: zrxkawboy]
#1810987
04/24/15 03:31 PM
04/24/15 03:31 PM
John_Kunkel
Rio Linda, CA
Friction modifiers can either increase or decrease the coefficient of friction a fluid has, depends on what the formulator wants.
[Re: putts000]
#1811128
04/24/15 08:10 PM
04/24/15 08:10 PM
Posts: 905 SD
zrxkawboy
SD
Again, John, see my post above. Type F is "grippy" (less slippage of friction materials) because it has no FM. Dex has a moderate amount, and ATF+4 has a high amount (that's why it's called a HFM ATF). I know of no ATF that uses increased amounts of FM to make it "less slippery". If you can provide any credible evidence of one, I'd be very interested in seeing it.
