Oil filter question
#1810704
04/24/15 02:08 AM
04/24/15 02:08 AM
Thumperdart
State of confusion
After reading about the k&n oil filters being made in China, are the racing fram filters any good since I usually shop at OReilly`s and don't think they carry wix.
Re: Oil filter question
[Re: Thumperdart]
#1810705
04/24/15 02:16 AM
04/24/15 02:16 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Is there a Napa near by. They usually carry Napa gold and Wix.
[Re: Thumperdart]
#1810714
04/24/15 02:35 AM
04/24/15 02:35 AM
Posts: 52,972 Romeo MI
MR_P_BODY
After reading about the k&n oil filters being made in China, are the racing fram filters any good since I usually shop at OReilly`s and don't think they carry wix. I was with a buddy out at the track helping his kid.. when he lost most of his oil pressure.. this was about 4 or 5 years ago and when I seen he was running a Fram I went to the local parts store and picked up 2 qts of oil and a Wix.. changed filters and added a qt of oil... pressure was right back up to normal... even to this day both of them keep asking how I knew it wasnt a engine problem.. I just said and still say... been there ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Thumperdart]
#1810716
04/24/15 02:51 AM
04/24/15 02:51 AM
Posts: 12 Oregon
Pstew
After reading about the k&n oil filters being made in China, are the racing fram filters any good since I usually shop at OReilly`s and don't think they carry wix. I just saw online today that O'rielly's carries Wix.
[Re: Pstew]
#1810719
04/24/15 03:04 AM
04/24/15 03:04 AM
Thumperdart
State of confusion
Been a Kragens/OReilly customer for years and spent thousands there but also shop at Napa and Auto zone when needed so that's good news and one's right down the street in Vegas which will get most of my business. I thought the Fram hp series were good but guess not.
[Re: Thumperdart]
#1810752
04/24/15 08:19 AM
04/24/15 08:19 AM
Posts: 10,021 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Wix racing filter, 51515R, 28 gpm flow, stock type filters are 7 gpm flow. Napa, I had to order them from their warehouse, about $10.
[Re: gregsdart]
#1810753
04/24/15 08:25 AM
04/24/15 08:25 AM
Quicktree
search youtube on filters look at the contruction, I wouldn't put a fram product on anything. order wix online
[Re: Thumperdart]
#1810774
04/24/15 09:52 AM
04/24/15 09:52 AM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
Oreilly's here carries Wix. NAPA gold is a Wix filter.
[Re: super451b]
#1810813
04/24/15 11:29 AM
04/24/15 11:29 AM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
I buy all my vehicles filters from here.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: Eric]
#1810835
04/24/15 12:07 PM
04/24/15 12:07 PM
Thumperdart
State of confusion
Thankxxx guys I'll look into the wix filters but need good filtration since I drive my dart way more than I race so not sure on the racing filters.
[Re: Thumperdart]
#1810853
04/24/15 12:24 PM
04/24/15 12:24 PM
an8sec70cuda
I just use the normal Wix filter on my stuff. Wix 51515 or Napa Gold 1515
[Re: rebel]
#1810867
04/24/15 12:46 PM
04/24/15 12:46 PM
Posts: 189 Virginia
64HemiSavoy
Virginia
Wix, Fram, AC Delco, Genuine Toyota, are made in the same factory down under. they don't make every filter in the range but the ones they do are pretty much the same internals. just the paint job on the casing is different. Take WIX from your down under list.... states sales are made in the States. http://www.wixfilters.com/About/PlantLocations.aspx
[Re: an8sec70cuda]
#1810869
04/24/15 12:49 PM
04/24/15 12:49 PM
Posts: 16,932 NC
440Jim
NC
I just use the normal Wix filter on my stuff. Wix 51515 or Napa Gold 1515 WIX 51515 = NAPA 1515 BB Mopar, 21 micron media, 7-9 GPM WIX 51515R = NAPA 1515R BB Mopar race, 61 micron media, 28 GPM I buy them using the Moparts discount on filter1.com Both are good, IMO. I run the 51515 on my street BB, and the 51515R on my race engine
[Re: 440Jim]
#1810903
04/24/15 01:24 PM
04/24/15 01:24 PM
dogdays
It's useless to try to talk sense about filters, they are like a religion.
From a lubrication point of view, the oil filters people put on their automobiles aren't much more than screens to keep the larger particles out.
If one was truly interested in filtering, one would use in addition to the screen oil filter, a bypass or "kidney loop" filter arrangement with a 5 micron absolute filter. Now, THAT would be real filtering. It'd also probably be beneficial to collect varnish.
In any discussion about oil filters, there are so many "facts" thrown around that are just so much horsemanure.
The real question that no one asks is what is the filtering media? If the filter doesn't use synthetic filter media it's a waste to put a lot of worry into filter selection.
Making filters out of ground-up trees doesn't give much selection as to particle size, because the fibers and the resultant holes are all over the map. The fact that cellulose fiber filters work for automobiles is indicative of the fact that the filter doesn't do very much.
Synthetic fibers can have size controlled much more closely and result in more uniform holes. They filter better. They do cost more. If you truly believe that the oil filter has an effect on engine life or performance, you should be willing to spend the extra $ to get a better filter.
Most all particles in a broken-in engine come from the air side of the engine. Air filters knock most of this out, so the filter now is there mainly to collect particles generated by a failure that is taking place.
But most of you don't want to know the real facts about oil filtration and instead enjoy engaging in wars about whose religion will get you to Heaven faster.
Such a waste of effort.
R.
[Re: Thumperdart]
#1810906
04/24/15 01:28 PM
04/24/15 01:28 PM
Posts: 7,506 Az
Crizila
Az
Just my opinion, but if you are not paying at least $10 for a filter ( pick a brand ) you are buying cheap stuff and putting your motor at risk. Buy a few 2,3,4 $ filters and cut them up - measure the can and base plate thickness. Then do the same thing with a 10,11,12 $ filter. You will quickly see the difference. Improved quality in filtering media will also be visibly apparent. Cheap insurance!
Fastest 300
