Where does the neutral safety switch connect #1810084
04/23/15 12:42 PM
04/23/15 12:42 PM
Rhode Island
jml19621 Offline OP
jml19621  Offline OP
Rhode Island
Come to find out the neutral safety switch and harness on on my 1970 Cuda 383 four barrel where never put on. It has an automatic transmission. I have purchased one from year one. Its on its way. I have looked at the wiring diagram and I am confused. where does it connect on the fuse block or is there a place on the steering column wiring harness?
True, I am taking the easy way out here, but at this point I am worn out. I am a rather big guy and I don't feel like crawling under the dash or anything else at this point until I know where I am going. I know it is a stupid question but every time I think its done, something comes up. Thanks for the help.
Jeff
Re: Where does the neutral safety switch connect [Re: jml19621] #1810123
04/23/15 01:30 PM
04/23/15 01:30 PM
Pittsburgh, PA
Slotts Offline
Slotts  Offline
Pittsburgh, PA
Hey Jeff,
That will be a piece of cake for you to connect. Your new harness will connect onto the three pin tranny switch and run up the firewall to the bulkhead 4 pin connect that is a mirror image of the wiper motor connection.
That's a plug and play piece of work!
Re: Where does the neutral safety switch connect [Re: Slotts] #1810217
04/23/15 03:45 PM
04/23/15 03:45 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The separate brown wire hooks to the "G" terminal on the starter relay. Harness routes in the pic below.
Re: Where does the neutral safety switch connect [Re: John_Kunkel] #1810354
04/23/15 07:16 PM
04/23/15 07:16 PM
Bellevue,Mich.
Dodge33 Offline
Dodge33  Offline
Bellevue,Mich.
Not to steal the thread, where would someone get the attachment brackets? Thanks in advance
Re: Where does the neutral safety switch connect [Re: Dodge33] #1810408
04/23/15 08:16 PM
04/23/15 08:16 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Auveco rubber coated clamps would work I think?. Get em at auto parts and auto paint supply's stores, they sell Auveco.
link
I might have the size your looking for? What size is it I wonder, what size is the bolt? I'll send you a couple if I have the right size.
Re: Where does the neutral safety switch connect [Re: Challenger 1] #1810431
04/23/15 08:49 PM
04/23/15 08:49 PM
Bellevue,Mich.
Dodge33 Offline
Dodge33  Offline
Bellevue,Mich.
My car is a 4 speed, the bell housing is 3/8. Anybody know if the other attachment goes to the tailshaft? My 69 shop manual is not handy. Thanks is advance thanks challenger 1
