383 forged crank in a 400 block why not? #1809604
04/22/15 05:47 PM
04/22/15 05:47 PM
texas
jdralph Offline OP
jdralph  Offline OP
texas
Why would you not put a 383 forged crank in a 400 block?
Re: 383 forged crank in a 400 block why not? [Re: jdralph] #1809605
04/22/15 05:50 PM
04/22/15 05:50 PM
an8sec70cuda Offline
B/c it's so easy to put a big stroker crank in one. That's the only reason I know of. drive
Seriously though...there isn't a reason really. Just have it balanced for the heavier 400 slugs, use the internally balanced damper and flexplate, and should be good to go.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 383 forged crank in a 400 block why not? [Re: jdralph] #1809610
04/22/15 05:54 PM
04/22/15 05:54 PM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
Early 400s that came in 4 speed cars had a steel crank, most likely leftover 383 cranks that were rebalanced.
Re: 383 forged crank in a 400 block why not? [Re: jdralph] #1809611
04/22/15 05:55 PM
04/22/15 05:55 PM
AndyF Offline
AndyF  Offline
Works fine. I have a 400 engine for my Duster that uses a 383 forged crank with Hemi rods and stroker pistons. It is a nice combo that really winds the clock.
Re: 383 forged crank in a 400 block why not? [Re: jdralph] #1809624
04/22/15 06:23 PM
04/22/15 06:23 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Makes for a VERY strong platform to build on. I would guess one of the better cheaply built power adder combo's you could do.
Re: 383 forged crank in a 400 block why not? [Re: jdralph] #1809629
04/22/15 06:41 PM
04/22/15 06:41 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Look back at that orange Challenger built way back by I think SD Concepts, it had a 400 block/383 crank with a Procharger making in the 1100 hp range IIRC, think it even had B1 heads.
Mopar to the bone!!!
Re: 383 forged crank in a 400 block why not? [Re: 451Cuda] #1809639
04/22/15 07:13 PM
04/22/15 07:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I wouldn't be surprised if the '68-'69 383 piston weighs about the same as a 400 piston...400 is larger in diameter but the 383 has a higher compression height.
Hollander shows the 383 and 400 forged as a direct interchange.
Re: 383 forged crank in a 400 block why not? [Re: jdralph] #1809671
04/22/15 08:22 PM
04/22/15 08:22 PM
sing sing
U
unknown Offline
unknown  Offline
U
sing sing
I did a 383 crank in a 400 block, internally balanced now.
Re: 383 forged crank in a 400 block why not? [Re: unknown] #1809679
04/22/15 08:34 PM
04/22/15 08:34 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
We have a 383 crank in my sons 400. And of course we had it internall balanced. Ron
Re: 383 forged crank in a 400 block why not? [Re: jdralph] #1809714
04/22/15 09:35 PM
04/22/15 09:35 PM
dogdays Offline
dogdays  Offline
DUH!!!!!!
How many times do we have to go over this?
In the late run of 383s, they used a cast crank with external balance. When the 400 came out, the cast crank versions used THE EXACT SAME CRANK AND EXTERNAL BALANCERS. Meaning that what was attached to each crank was THE SAME.
The same thing happened with forged cranks. The EXACT SAME CRANK went into forged crank 383s and 400s. Chrysler kept piston weights the same to allow them to do these kind of swaps. Shoot, when the 273 came out it had a special thickwall pin so they could use the same crank as the poly 318s. Chrysler was a company that was strong on engineering and that means they were very good at figuring out what they could get away with.
Plus, the factory balance jobs were nowhere near as accurate as people think is necessary nowadays. AND, people who bought Mopars didn't flood the dealerships with complaints about the engine vibrating.
All of this "you have to balance because there's an 11 gram difference in piston weight" horsepoop is just that.....horse poop.
Now I agree that perfection is better than nonperfection. But how much money is it worth?
There is a board member who I respect as having raced a lot of smallblocks who replaced his factory 318 pistons, 591 grams, with KB 167s, 507 grams, and ran the engine and he claims it didn't run any rougher. I believe him.
Ever hear of overbalancing? Underbalancing? They do it on purpose to race engines. What we think of as God's truth about balancing a V8 is mostly what was figured out to work about as well as it could work. It is empirically driven, not deriveable from mathematics.
For one thing, piston motion is NOT a perfect sine wave.
R.
Chew on that!
Re: 383 forged crank in a 400 block why not? [Re: dogdays] #1809780
04/22/15 10:47 PM
04/22/15 10:47 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I think the OP is asking this since most 400's are cast cranks and most 383's are forged cranks. Ron
Re: 383 forged crank in a 400 block why not? [Re: 383man] #1809817
04/22/15 11:36 PM
04/22/15 11:36 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
Im still amazed at how many mopar guys still insist that all 400 cranks were cast..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: 383 forged crank in a 400 block why not? [Re: 72N96RR] #1809863
04/23/15 12:22 AM
04/23/15 12:22 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I know all 400's were not cast but I do agree most of the ones you see are cast. Or I know most of the 400's I see are cast but of course they are forged 400 cranks out there just not alot of them. Ron
Re: 383 forged crank in a 400 block why not? [Re: 383man] #1810103
04/23/15 01:10 PM
04/23/15 01:10 PM
dogdays Offline
dogdays  Offline
Answer to the original question - No reason why not, people have been swapping them back and forth for decades. Reread my rant above, which came after a long day at work answering dumb questions.
R.
Re: 383 forged crank in a 400 block why not? [Re: 383man] #1810983
04/24/15 03:26 PM
04/24/15 03:26 PM
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
That was not directed at you Ron..!!! beer
