dodge diesel intank pump #180931
01/01/09 08:47 PM
01/01/09 08:47 PM
Oh Canada
E
EV2CUDA Offline OP
EV2CUDA  Offline OP
E
Oh Canada
My pump in the tank died. Is there a high perf replacement for it? I wanted to add a holley blue pump before the intank died but now what to do? Replace the intank and then add a blue? I run a chip and need the extra fuel delivery.
71 Barracuda 383 4spd (500ci)
69 camaro 598, NOS
69 barracuda bbc procharger
77 t/a 6.0 turbo project
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
78 Warlock 5.7 hemi project
Re: dodge diesel intank pump [Re: EV2CUDA] #180932
01/01/09 08:58 PM
01/01/09 08:58 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
Fass systems are pumps and filters. www.FASSride.com hope this helps
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: dodge diesel intank pump [Re: hulmule] #180933
01/01/09 09:08 PM
01/01/09 09:08 PM
Mesa , Az
Jambbii Offline
Jambbii  Offline
Mesa , Az
Here is another option too.
http://www.glacierdieselpower.com/
I have installed most of the kits too (airdog , fuel boss etc) Good customer service at glacier also.
Josh
70 Challenger
1960 Town Wagon P Pump 24v cummins project
06 Mega 3500 Drw 2wd
12 Durango R/T
18 Power Wagon
67 A100
Re: dodge diesel intank pump [Re: EV2CUDA] #180934
01/01/09 09:45 PM
01/01/09 09:45 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
What year truck? and what mods? What have you done to diag this?
Re: dodge diesel intank pump [Re: J_BODY] #180935
01/01/09 10:33 PM
01/01/09 10:33 PM
Oh Canada
E
EV2CUDA Offline OP
EV2CUDA  Offline OP
E
Oh Canada
I've got an edge with a juice monitor. Fuel pressure lately was bouncing back and forth from 8 psi and up to 3 psi at times. Today it worked good, shut it off for a couple of hours and went to start it, went up to 3 and ran bad for 5 seconds, now it has 0 psi. and will not run or try to start.
69 camaro 598, NOS
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
Re: dodge diesel intank pump [Re: EV2CUDA] #180936
01/01/09 11:11 PM
01/01/09 11:11 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
.....and the year???
Re: dodge diesel intank pump [Re: EV2CUDA] #180937
01/01/09 11:32 PM
01/01/09 11:32 PM
N
NITROUSN Offline
NITROUSN  Offline
N
What year?
You may have line that are bad and you are sucking air.
As far as lift pumps go my stock carter went 104,000 and I put a replacement carter back on.I watched my old pump slowly die. I had the replacement for about 3 years sitting in the truck just in case. It was a cummins campaign pump that my buddy who runs a big truck shop got for me for less than 70 bucks. I now have an airtex for a spare and that set me back 119.00. I dont fall into these big dick pumps in the 4 to 6 hundred dollar range. They have their failure rates to. Dont buy into all this VP44 and lift pump Myths and mis-information.
Re: dodge diesel intank pump [Re: NITROUSN] #180938
01/02/09 07:55 AM
01/02/09 07:55 AM
Oh Canada
E
EV2CUDA Offline OP
EV2CUDA  Offline OP
E
Oh Canada
Its an 01 which I believe has an in tank lift pump.
What I would like to do, if I can, is to remove the in tank pump, replace with a fuel line and just install a blue or black pump on the frame.
69 camaro 598, NOS
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
Re: dodge diesel intank pump [Re: EV2CUDA] #180939
01/02/09 09:52 AM
01/02/09 09:52 AM
N
NITROUSN Offline
NITROUSN  Offline
N
01 did not have an intank pump when new. If it does now it was added. What makes you think it has the in tank pump? Turn the key on. Bump the starter and you should be able to hear and locate the pump if its running. A holley blue or black would be my absolute worse pump to use IMO.
Re: dodge diesel intank pump [Re: EV2CUDA] #180940
01/02/09 10:16 AM
01/02/09 10:16 AM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
Re: dodge diesel intank pump [Re: Blown71X] #180941
01/02/09 11:49 AM
01/02/09 11:49 AM
Oh Canada
E
EV2CUDA Offline OP
EV2CUDA  Offline OP
E
Oh Canada
Its stock so I am wrong about the pump it looks. I can not hear the pump anymore as I used to hear it before it quit yesterday. I will look for where the pump is. Why will the holley pumps not work well? I have googled this and have found a few posts mentioning this as an economical and long lasting patch for the lift pump problem. $600 for the other listed pumps above seems like alot if the holley works.
BTW no codes have shown up...
PS 5th gear went last week and over the last month, the steering on the beast went to Wandering all over the place. All at once! Looks like i will be a couple grand soon.
69 camaro 598, NOS
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
