dodge diesel intank pump
#180931
01/01/09 08:47 PM
01/01/09 08:47 PM
Posts: 738 Oh Canada
EV2CUDA
Oh Canada
My pump in the tank died. Is there a high perf replacement for it? I wanted to add a holley blue pump before the intank died but now what to do? Replace the intank and then add a blue? I run a chip and need the extra fuel delivery.
71 Barracuda 383 4spd (500ci) 69 camaro 598, NOS 69 barracuda bbc procharger 77 t/a 6.0 turbo project 78 t/a 400 77 corvette 1983 hurst/olds 03 Viper 79 360 macho 71 demon 360 78 Warlock 5.7 hemi project
Re: dodge diesel intank pump
[Re: EV2CUDA]
#180932
01/01/09 08:58 PM
01/01/09 08:58 PM
Posts: 1,412 northeast ohio
hulmule
northeast ohio
Fass systems are pumps and filters. www.FASSride.com hope this helps
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
[Re: hulmule]
#180933
01/01/09 09:08 PM
01/01/09 09:08 PM
Posts: 554 Mesa , Az
Jambbii
Mesa , Az
Here is another option too. http://www.glacierdieselpower.com/ I have installed most of the kits too (airdog , fuel boss etc) Good customer service at glacier also. Josh
70 Challenger 1960 Town Wagon P Pump 24v cummins project 06 Mega 3500 Drw 2wd 12 Durango R/T 18 Power Wagon 67 A100
[Re: J_BODY]
#180935
01/01/09 10:33 PM
01/01/09 10:33 PM
EV2CUDA
Oh Canada
I've got an edge with a juice monitor. Fuel pressure lately was bouncing back and forth from 8 psi and up to 3 psi at times. Today it worked good, shut it off for a couple of hours and went to start it, went up to 3 and ran bad for 5 seconds, now it has 0 psi. and will not run or try to start.
[Re: EV2CUDA]
#180936
01/01/09 11:11 PM
01/01/09 11:11 PM
Posts: 13,201 aZLiViN
J_BODY
aZLiViN
[Re: EV2CUDA]
#180937
01/01/09 11:32 PM
01/01/09 11:32 PM
Posts: 18,425 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
What year?
You may have line that are bad and you are sucking air.
As far as lift pumps go my stock carter went 104,000 and I put a replacement carter back on.I watched my old pump slowly die. I had the replacement for about 3 years sitting in the truck just in case. It was a cummins campaign pump that my buddy who runs a big truck shop got for me for less than 70 bucks. I now have an airtex for a spare and that set me back 119.00. I dont fall into these big dick pumps in the 4 to 6 hundred dollar range. They have their failure rates to. Dont buy into all this VP44 and lift pump Myths and mis-information.
[Re: NITROUSN]
#180938
01/02/09 07:55 AM
01/02/09 07:55 AM
EV2CUDA
Oh Canada
Its an 01 which I believe has an in tank lift pump. What I would like to do, if I can, is to remove the in tank pump, replace with a fuel line and just install a blue or black pump on the frame.
[Re: EV2CUDA]
#180939
01/02/09 09:52 AM
01/02/09 09:52 AM
NITROUSN
01 did not have an intank pump when new. If it does now it was added. What makes you think it has the in tank pump? Turn the key on. Bump the starter and you should be able to hear and locate the pump if its running. A holley blue or black would be my absolute worse pump to use IMO.
[Re: Blown71X]
#180941
01/02/09 11:49 AM
01/02/09 11:49 AM
EV2CUDA
Oh Canada
Its stock so I am wrong about the pump it looks. I can not hear the pump anymore as I used to hear it before it quit yesterday. I will look for where the pump is. Why will the holley pumps not work well? I have googled this and have found a few posts mentioning this as an economical and long lasting patch for the lift pump problem. $600 for the other listed pumps above seems like alot if the holley works. BTW no codes have shown up... PS 5th gear went last week and over the last month, the steering on the beast went to Wandering all over the place. All at once! Looks like i will be a couple grand soon.
