rubber pushrod retainer
#1808766
04/21/15 05:45 PM
04/21/15 05:45 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
The little rubber piece that goes on manual brake rods to secure it in the master cylinder...where can you get these? Thanks.
Moparlee
Re: rubber pushrod retainer
[Re: scratchnfotraction]
#1808816
04/21/15 07:01 PM
04/21/15 07:01 PM
RapidRobert
I did the same as Scratchn. The OE ones have a thin groove lengthwise alongside the OD from end to end possibly to let air excape so it will seat firmly in place either that or it is a mfr tool mark that is insignificant as far as functioning. Either way I added the groove/no issues. hand the p rod to your parts guy & have him cut a snip of whatever ID slips firmly on the round nub rod end just a hair shorter than the length of the recessed groove on the p rod (it'll likely be a freebe) & you're set
