904 band adj Q, how to: #1807673
04/20/15 12:49 PM
04/20/15 12:49 PM
RapidRobert Offline OP
adjusted front (closest to bell face) band till 1/4" between lever and round "button" in the center of the servo round flat disc. For the rear one I was given a dimention of 5/16" but the "cover" ain't flat & I cant tell where to set the clearance at. Also I was given 3 turns out so I tried that & I went in to 75 in lbs then back out 3 turns & there was no clearance. Short version: how/what do I set this band adj to? this is the one that is adjusted inside the pan. thank you for your time.
Re: 904 band adj Q, how to: [Re: RapidRobert] #1807801
04/20/15 03:35 PM
04/20/15 03:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Depends on the band i.e. single or double wrap.
Re: 904 band adj Q, how to: [Re: John_Kunkel] #1807838
04/20/15 04:21 PM
04/20/15 04:21 PM
John lemme go find out
Re: 904 band adj Q, how to: [Re: RapidRobert] #1808158
04/20/15 10:45 PM
04/20/15 10:45 PM
John it is a solid 1 piece/no gap band.
Re: 904 band adj Q, how to: [Re: RapidRobert] #1808824
04/21/15 07:17 PM
04/21/15 07:17 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The solid rear band is usually comfortable with 2 turns out.
Re: 904 band adj Q, how to: [Re: John_Kunkel] #1808999
04/21/15 10:07 PM
04/21/15 10:07 PM
John here's the problem I am having, I go in to 75 in lbs (my wrench is graduated in 25 in lb increments & I'm assuming 3 extra in lbs ain't a dealbreaker) then I come off 2 turns & the band is still tight/contacting the drum. I am assuming it needs to be free/have some clearance & if so then I am going in too far cuz coming back out 2 turns ain't loosening it up enough. More direction please
Re: 904 band adj Q, how to: [Re: RapidRobert] #1809282
04/22/15 10:59 AM
04/22/15 10:59 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Maybe your torque wrench is the problem, just snug it using a standard length 1/4 drive ratchet and come out 2 turns .
Re: 904 band adj Q, how to: [Re: JohnRR] #1809329
04/22/15 12:20 PM
04/22/15 12:20 PM
Alright I will do that today. something this simple should not be this hard.
Re: 904 band adj Q, how to: [Re: RapidRobert] #1809481
04/22/15 03:27 PM
04/22/15 03:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The problem with using a torque wrench on the rear servo is cushion spring in the center of the piston...if you tighten the adjuster stud enough, the cushion spring compresses when there is no play in the linkage so when the adjuster is backed off part of the travel is used in decompressing the spring.
It's better to turn the adjuster stud in until there is no perceptible slop when pulling down on the lever...use this as the zero point to back off the desired number of turns.
Re: 904 band adj Q, how to: [Re: John_Kunkel] #1809532
04/22/15 04:12 PM
04/22/15 04:12 PM
I will screw it in till I JUST get to zero lash just like your valvtrain then back off 2 turns. if this is correct I'm good & if not then post & correct me further. Thank you!
Re: 904 band adj Q, how to: [Re: RapidRobert] #1809869
04/23/15 12:31 AM
04/23/15 12:31 AM
I did the above & was pleasantly surprised when I ended up with a significant amount of clearance which was what I was worried about (that I would not have enough) & I'd burn it up. Thank you! I still think something ain't right to where it had to be tightened too far in using the torque wrench however, double R I will check out the wrench & go from there.
Re: 904 band adj Q, how to: [Re: RapidRobert] #1810265
04/23/15 04:59 PM
04/23/15 04:59 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
HaHa!! I was saying this exact thing all morning doing drum brakes on my son's Sunfire! all them springs and brackets and stuff jammed into such a tiny area with this god awful wheel hub smack in the way! mad
Re: 904 band adj Q, how to: [Re: mikemee1331] #1810280
04/23/15 05:16 PM
04/23/15 05:16 PM
HaHa!! I was saying this exact thing all morning doing drum brakes on my son's Sunfire! mad
persuade him to sell or trade it toward a 60's Mopar
Re: 904 band adj Q, how to: [Re: RapidRobert] #1810307
04/23/15 06:01 PM
04/23/15 06:01 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Jeep my friend, he wants a Wrangler (or my Road Runner)
