Thermostat housing
#1807438
04/20/15 01:55 AM
04/20/15 01:55 AM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
I am in need of a small block housing all of the inexpensive one seem to keep leaking. anyone had any luck with one that doesn't break the bank. I can use a straight up style or a 90 towards the drivers side Thanks,
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
Re: Thermostat housing
[Re: Stroker Scamp]
#1807542
04/20/15 09:51 AM
04/20/15 09:51 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Is the rail on the Mancini waterneck as thin as it looks in the photo? My chrome Moroso is already warped and leaking.
[Re: Stroker Scamp]
#1807546
04/20/15 09:57 AM
04/20/15 09:57 AM
ProSport
Akron, Ohio
I was also told that Napa sells a stock waterneck for $6 that seals well. And 440source has a chrome one with a super thick 1/2" base.
[Re: Stroker Scamp]
#1807611
04/20/15 11:43 AM
04/20/15 11:43 AM
Posts: 52,972 Romeo MI
MR_P_BODY
On my W-2 intake I had a issue.. there wasnt a shelve in the hole to set the thermostat on and the goose neck didnt have it either... I ended up welding a lip inside the hole and ground it for the thickness... I also used a larger stat and ground the OD down to just fit the hole... works fine now but what a PITA... I use a billet chevy housing since they are the same but this one has the O-ring and turnable hose fitting
[Re: shorthorse]
#1808212
04/20/15 11:38 PM
04/20/15 11:38 PM
ProSport
Akron, Ohio
After struggling with trying to seal a gasket style housing I bought a Billet Specialties (90820) housing with the o-ring. I bolted it on with no sealer, just using the o-ring. It's been off and on several times and hasn't leaked in 6 years of use. I bought another one for a new build and did the same, no sealer and no leaks. It's worth the extra money. That's good to know, I was looking at that one at Summit today.
[Re: 70AARcuda]
#1808214
04/20/15 11:39 PM
04/20/15 11:39 PM
ProSport
Akron, Ohio
Is it a good billet aluminum that won't warp? Looks like a nice piece if they're still available.
[Re: Mr340]
#1808219
04/20/15 11:50 PM
04/20/15 11:50 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have the same one and it is leak free
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: shorthorse]
#1808225
04/21/15 12:00 AM
04/21/15 12:00 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Same here....never any leaks. Rickster
[Re: Stroker Scamp]
#1809224
04/22/15 08:12 AM
04/22/15 08:12 AM
ProSport
Akron, Ohio
I'm gonna have to order the Mancini waterneck, I looked at the $6 one at Napa yesterday, looks like a nice quality piece but it doesn't have the widened area at the top of the snout to help hold the hose on, seems like it'd be easy for the hose to slip off.
[Re: Stroker Scamp]
#1809307
04/22/15 11:33 AM
04/22/15 11:33 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
I have the billet one from Mancini also. Been using it for several years and no leaks ever.
[Re: ProSport]
#1809786
04/22/15 10:54 PM
04/22/15 10:54 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Same pattern as Chevy but Mopars have a recess in the flange for a t-stat. Chevy the recess is in the intake.
"Just a Bracket car dressed up like a streetcar"
[Re: Stroker Scamp]
#1809802
04/22/15 11:18 PM
04/22/15 11:18 PM
ProSport
Akron, Ohio
That's good to know. I thought the recess was a different size, requiring a chevy thermostat. Didn't know the recess was in the intake. I had my heart set on that $17 billet piece!
I like the $28 billet 440source waterneck and their $15 chrome one with the 1/2" thick base, I just didn't want to have to order it and wait for it. Shipping is $9.99 for each. It sucks to be on a tight budget and a tight time schedule.
[Re: 70AARcuda]
#1810047
04/23/15 11:45 AM
04/23/15 11:45 AM
ProSport
Akron, Ohio
It says they're solid aluminum, does that mean it's billet or not? I'm about to buy the $17 billet Chevy piece from Summit and just not run a thermostat lol. I've never even ran a thermostat in my previous cars but they had electric water pumps.
[Re: fourgearsavoy]
#1810086
04/23/15 12:45 PM
04/23/15 12:45 PM
Posts: 7,506 Az
Crizila
Az
Me 3. no leaky.
Fastest 300
