Thermostat housing #1807438
04/20/15 01:55 AM
04/20/15 01:55 AM
pacific northwest
Stroker Scamp Offline OP
pacific northwest
I am in need of a small block housing all of the inexpensive one seem to keep leaking. anyone had any luck with one that doesn't break the bank. I can use a straight up style or a 90 towards the drivers side
Thanks,
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Thermostat housing [Re: Stroker Scamp] #1807499
04/20/15 03:28 AM
04/20/15 03:28 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
This is the best one I have used
http://www.manciniracing.com/mabialwane.html
"Just a Bracket car dressed up like a streetcar"
Re: Thermostat housing [Re: Stroker Scamp] #1807542
04/20/15 09:51 AM
04/20/15 09:51 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Is the rail on the Mancini waterneck as thin as it looks in the photo? My chrome Moroso is already warped and leaking.
Re: Thermostat housing [Re: Stroker Scamp] #1807546
04/20/15 09:57 AM
04/20/15 09:57 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I was also told that Napa sells a stock waterneck for $6 that seals well.
And 440source has a chrome one with a super thick 1/2" base.
Re: Thermostat housing [Re: Just-a-dart] #1807575
04/20/15 10:47 AM
04/20/15 10:47 AM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
iagree
Re: Thermostat housing [Re: Stroker Scamp] #1807611
04/20/15 11:43 AM
04/20/15 11:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
On my W-2 intake I had a issue.. there wasnt a shelve in the
hole to set the thermostat on and the goose neck didnt have it
either... I ended up welding a lip inside the hole and ground
it for the thickness... I also used a larger stat and ground
the OD down to just fit the hole... works fine now but what a
PITA... I use a billet chevy housing since they are the same
but this one has the O-ring and turnable hose fitting
wave
Re: Thermostat housing [Re: Stroker Scamp] #1808011
04/20/15 07:50 PM
04/20/15 07:50 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
After struggling with trying to seal a gasket style housing I bought a Billet Specialties (90820) housing with the o-ring. I bolted it on with no sealer, just using the o-ring. It's been off and on several times and hasn't leaked in 6 years of use. I bought another one for a new build and did the same, no sealer and no leaks. It's worth the extra money.
Re: Thermostat housing [Re: shorthorse] #1808015
04/20/15 07:54 PM
04/20/15 07:54 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
http://www.ebay.com/itm/DODGE-MOPAR-318-...9d8&vxp=mtr
got a few of these went they were half this price....
Tony
70 AARCuda Vitamin C
Re: Thermostat housing [Re: shorthorse] #1808212
04/20/15 11:38 PM
04/20/15 11:38 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
That's good to know, I was looking at that one at Summit today.
Re: Thermostat housing [Re: 70AARcuda] #1808214
04/20/15 11:39 PM
04/20/15 11:39 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Is it a good billet aluminum that won't warp? Looks like a nice piece if they're still available.
Re: Thermostat housing [Re: Mr340] #1808219
04/20/15 11:50 PM
04/20/15 11:50 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
iagree
I have the same one and it is leak free
64 Plymouth Savoy
Dana 60
Re: Thermostat housing [Re: shorthorse] #1808225
04/21/15 12:00 AM
04/21/15 12:00 AM
Lehigh Acres, Florida
rickstershemi Offline
Same here....never any leaks.
Rickster
Re: Thermostat housing [Re: Stroker Scamp] #1808267
04/21/15 12:47 AM
04/21/15 12:47 AM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I bought mine from Roger Gibson about 7 years ago and no problems.
http://www.rogergibsonautorestoration.com/products.htm
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Thermostat housing [Re: Stroker Scamp] #1809224
04/22/15 08:12 AM
04/22/15 08:12 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I'm gonna have to order the Mancini waterneck, I looked at the $6 one at Napa yesterday, looks like a nice quality piece but it doesn't have the widened area at the top of the snout to help hold the hose on, seems like it'd be easy for the hose to slip off.
Re: Thermostat housing [Re: Stroker Scamp] #1809307
04/22/15 11:33 AM
04/22/15 11:33 AM
an8sec70cuda Offline
I have the billet one from Mancini also. Been using it for several years and no leaks ever.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Thermostat housing [Re: Stroker Scamp] #1809737
04/22/15 09:59 PM
04/22/15 09:59 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
This billet aluminum water neck is only $17 for a Chevy and I've read that the Chevy ones are the same bolt pattern as Mopar. The thermostat might be different but those are cheap.
Billet aluminum won't warp, is that correct?
http://www.summitracing.com/parts/spe-4931/overview/make/chevrolet
Re: Thermostat housing [Re: ProSport] #1809786
04/22/15 10:54 PM
04/22/15 10:54 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Same pattern as Chevy but Mopars have a recess in the flange for a t-stat. Chevy the recess is in the intake.
Re: Thermostat housing [Re: Stroker Scamp] #1809802
04/22/15 11:18 PM
04/22/15 11:18 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
That's good to know. I thought the recess was a different size, requiring a chevy thermostat. Didn't know the recess was in the intake.
I had my heart set on that $17 billet piece!
I like the $28 billet 440source waterneck and their $15 chrome one with the 1/2" thick base, I just didn't want to have to order it and wait for it. Shipping is $9.99 for each.
It sucks to be on a tight budget and a tight time schedule.
Re: Thermostat housing [Re: 70AARcuda] #1810047
04/23/15 11:45 AM
04/23/15 11:45 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
It says they're solid aluminum, does that mean it's billet or not?
I'm about to buy the $17 billet Chevy piece from Summit and just not run a thermostat lol.
I've never even ran a thermostat in my previous cars but they had electric water pumps.
Re: Thermostat housing [Re: fourgearsavoy] #1810086
04/23/15 12:45 PM
04/23/15 12:45 PM
Az
Crizila Offline
Crizila  Offline
Az
Me 3. no leaky.
Fastest 300
