Distributor wired directly to the coil???? #1807117
04/19/15 07:08 PM
04/19/15 07:08 PM
Davenport,Fl
hdphilbo Offline OP
hdphilbo  Offline OP
Davenport,Fl
I just Bought a 1970 Dodge challenger .originally a 383 car.now a 73 440.i was doing my initial inspection when i found the coil was very hot and the car hadn't been run in 7 hrs.upon further inspection.i noticed the distributor wired directly to the coil.there's no Mopar Orange,silver or gold box????Im wondering WTF is going on with this thing?any IDEA"S???
Re: Distributor wired directly to the coil???? [Re: hdphilbo] #1807147
04/19/15 07:28 PM
04/19/15 07:28 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
points ignition probably. Key in run position and points closed would cause your symptoms. Electronic ignition did not be come standard will later than 70.
Don't be the exception.
Re: Distributor wired directly to the coil???? [Re: hdphilbo] #1807157
04/19/15 07:34 PM
04/19/15 07:34 PM
Davenport,Fl
hdphilbo Offline OP
hdphilbo  Offline OP
Davenport,Fl
not points.pulled the cap to check
Re: Distributor wired directly to the coil???? [Re: hdphilbo] #1807234
04/19/15 09:18 PM
04/19/15 09:18 PM
Ct, Oxford
340swing Offline
340swing  Offline
Ct, Oxford
pertronix?
Re: Distributor wired directly to the coil???? [Re: 340swing] #1807264
04/19/15 10:03 PM
04/19/15 10:03 PM
Davenport,Fl
hdphilbo Offline OP
hdphilbo  Offline OP
Davenport,Fl
no, mopar electronic
Re: Distributor wired directly to the coil???? [Re: hdphilbo] #1807291
04/19/15 10:35 PM
04/19/15 10:35 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
If it is a stock Mopar electronic distributor, it'll need to have an ECU somewhere or other...
Might need to chase the wires around to see if they hid something somewhere?
At least see how it is wired how it is, then diagnose from there.
Re: Distributor wired directly to the coil???? [Re: OzHemi] #1807487
04/20/15 02:51 AM
04/20/15 02:51 AM
What Oz said, describe specifically what hard components you have (ECU/ballast/coil/dist) and how they are wired
