Re: Distributor wired directly to the coil????
[Re: hdphilbo]
#1807147
04/19/15 07:28 PM
04/19/15 07:28 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
points ignition probably. Key in run position and points closed would cause your symptoms. Electronic ignition did not be come standard will later than 70.
[Re: OzHemi]
#1807487
04/20/15 02:51 AM
04/20/15 02:51 AM
RapidRobert
What Oz said, describe specifically what hard components you have (ECU/ballast/coil/dist) and how they are wired
