Page 9 of 11 1 2 7 8 9 10 11
Re: My Gen III Hemi A-body build. [Re: RylisPro] #1552427
03/08/15 12:48 AM
03/08/15 12:48 AM
Nebraska
72Swinger Offline OP
Nebraska
As I get my firewall to A pillar bars done I can start wiring for real, got the passenger side done today will get the other one soon. Those bars are going to dictate my fuse box mounting,ecm mounting and voltage regulator, Bat + junction and buss bar placement. Going to have through firewall battery 3/8" studs for pos and neg both behind the cylinder heads as hidden as possible. Been thinking I might mount an encased 200 amp fuse inline with the charge wire to. Firewall is almost done with filler and smoothing, still need to cut out master cylinder plate and weld in a new one out of 1/8" and plate in the down bars to the shock mounts a little then the engine compartment will be in paint soon after.
Mopar to the bone!!!
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1552428
03/08/15 02:11 AM
03/08/15 02:11 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
When Monte is talking about the floating ground copper bus bar,
does he mean something like this?
http://www.electrical-insulators-and-copper-ground-bars.com/segrbaki.html
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: My Gen III Hemi A-body build. [Re: RylisPro] #1552429
03/08/15 07:45 AM
03/08/15 07:45 AM
moparx Online content
moparx  Online Content
that will work !
Re: My Gen III Hemi A-body build. [Re: RylisPro] #1552430
03/08/15 09:08 AM
03/08/15 09:08 AM
Nebraska
Nebraska
yes, his theory is any grounds to frame amplify electrical noise exponentially.
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1552431
03/08/15 01:34 PM
03/08/15 01:34 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Ok, just remembered that I actually did a similar setup for the positive cable using this red covered terminal block JB4-375-RC.
http://www.texasindustrialelectric.com/_junction_blocks.asp
For my negative I ran a fat 00 cable from the engine block to the battery negative but ran other grounds to the frame.
I will get this black terminal block instead
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: My Gen III Hemi A-body build. [Re: RylisPro] #1552432
03/31/15 06:21 AM
03/31/15 06:21 AM
Nebraska
Nebraska
So I was putting my sweet newly covered dash pad in the shed and saw that my driver side fender had slid from its perch on top of a bunch of other junk and hit a dolley and my lawn mower on the way down to landing face down on the concrete. Not a morale boost this guy. Its gonna need paint to fix, AAAAAAAARRRRRRR!!!
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1805361
04/17/15 12:24 AM
04/17/15 12:24 AM
Nebraska
Nebraska
Trudging on through...gotta thank my buddy Travis for laying down a killer few coats of B5 over this amatuers first go at body work.
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1806472
04/18/15 08:54 PM
04/18/15 08:54 PM
Nebraska
Nebraska
Finally going together! Went smooth as silk using the install car on engine method.
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1806548
04/18/15 11:16 PM
04/18/15 11:16 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
This looks amazing Emil! Great job
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1806576
04/18/15 11:41 PM
04/18/15 11:41 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Sweet!
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1806592
04/19/15 12:07 AM
04/19/15 12:07 AM
Nebraska
Nebraska
Thanks guys, I have a ton of stuff left to iron out but man does it feel good to get going. Im not gonna predict any "it will run by 0000 day" crap to add pressure either lol!
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1806595
04/19/15 12:10 AM
04/19/15 12:10 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I'm at a stagnant point with mine where I feel like I'm just pecking away at the same thing over and over. Hoping to get the engine bay relatively wrapped up here soon and stab my mock up engine in there!
2020 RAM 1500
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1806661
04/19/15 01:54 AM
04/19/15 01:54 AM
Nebraska
Nebraska
Definitely mock up BEFORE engine bay is painted. I have kept my engine bay scratch free so far because of that. BUT even though the clutch master has a plastic cap over the outlet fitting DOES NOT mean it wont still freaking DRIP! If anyone sees the mark that made, ill kick them in the nads....
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1806712
04/19/15 04:27 AM
04/19/15 04:27 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
This is the first time I've looked in this thread and I've only seen this page. I like the "tubs" in the engine bay. I'm curious about them. Do you intend to lower the car with tall tires and need that extra clearance?
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1806873
04/19/15 01:39 PM
04/19/15 01:39 PM
Nebraska
Nebraska
They are needed with high offset wheels and 10-12 wide tires IMO. I plan to eventually run a 295 on the front some day. Just something I did since I was already taking the engine compartment down anyway.
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1806997
04/19/15 04:17 PM
04/19/15 04:17 PM
Texas
6packattk Offline
6packattk  Offline
Texas
Looks awesome my brother,keep pics coming with all progress
bow
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1807107
04/19/15 06:55 PM
04/19/15 06:55 PM
Nebraska
Nebraska
Thanks Brutha, get well!
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1807325
04/19/15 11:17 PM
04/19/15 11:17 PM
Nebraska
Nebraska
OK last pic until I get an idle video.
Re: My Gen III Hemi A-body build. [Re: 72Swinger] #1807336
04/19/15 11:31 PM
04/19/15 11:31 PM
Saint Peters, MO
Brian Offline
Brian  Offline
Saint Peters, MO
That looks sweet! I hope mine will look that good in few more months.
1971 6.1 Gen III Hemi Duster
Re: My Gen III Hemi A-body build. [Re: Brian] #1807411
04/20/15 01:20 AM
04/20/15 01:20 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Looks nice. The stock hood should clear just fine!
