Trans question #1804563
04/15/15 11:48 PM
04/15/15 11:48 PM
nielsville, minn.
Q
quickd100 Offline OP
Q
nielsville, minn.
Does anyone know the overall length of a shortshaft torqueflite vs a powerglide? A buddy and I are looking at a FED chassis, it's setup for a Hemi and glide and I'd like to run a torqueflite if possible.Dave
Re: Trans question [Re: quickd100] #1804597
04/16/15 12:12 AM
04/16/15 12:12 AM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
No disrespect meant, but why run a TF?
" The last official act of any goverment, is to loot the treasury" George Washington
Re: Trans question [Re: quickd100] #1804621
04/16/15 12:28 AM
04/16/15 12:28 AM
nielsville, minn.
Q
Q
nielsville, minn.
We've got lots of parts for T-flites including convertors.
Re: Trans question [Re: quickd100] #1804756
04/16/15 06:17 AM
04/16/15 06:17 AM
gregsdart Online content
gregsdart  Online Content
Sounds to me like that 605 in a FED leaving in second gear (Torqueflite) ought to rock smile
Re: Trans question [Re: quickd100] #1804774
04/16/15 07:50 AM
04/16/15 07:50 AM
nielsville, minn.
Q
Q
nielsville, minn.
Greg, Kevin and I are looking at one, it had been set up with a blown Hemi. If things check out we'd probably throw a mild wedge in it to get our feet wet. Down the road a 605 might end up between the frame rails.Dave
Re: Trans question [Re: quickd100] #1804847
04/16/15 11:36 AM
04/16/15 11:36 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
if the TF makes you move the engine forward...... you are definitely going in the wrong direction.
Re: Trans question [Re: quickd100] #1804872
04/16/15 12:20 PM
04/16/15 12:20 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
There is a 4wd version that has a pretty short tailshaft. Mid-'70s I believe when they used a short driveshaft between the trans and transfer case. Should be similar in length to a Glide.
Re: Trans question [Re: slantzilla] #1804878
04/16/15 12:29 PM
04/16/15 12:29 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
A shorty kit from Cope Racing would make it even shorter.
But the length on a truck short tailshaft transmission is 30.58" without the yoke, 34.12 with. Should be found in 72-74 4wd and I think all 2wd. I don't know how long powerglides are.
Re: Trans question [Re: quickd100] #1805000
04/16/15 03:18 PM
04/16/15 03:18 PM
nielsville, minn.
Q
Q
nielsville, minn.
I've seen the short 2wd TF in a 81' 1/2T club cab. I just didn't know length. Dave
Re: Trans question [Re: quickd100] #1805134
04/16/15 07:07 PM
04/16/15 07:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
"Short" is a relative term; the shortest 727 tail that I've seen was used with the divorced transfer case circa early seventies.
Keep in mind that the factory tailhousing had to be long enough to contain the park/governor assembly. The aftermarket setup would likely be the shortest because it has no provisions for the governor.
Re: Trans question [Re: John_Kunkel] #1805348
04/17/15 12:08 AM
04/17/15 12:08 AM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
This is the best picture I can get of my 74 4x4 truck, measured from the engine block along the top. They are pretty short but not powerglide short without the aftermarket kit.
Re: Trans question [Re: quickd100] #1806141
04/18/15 10:59 AM
04/18/15 10:59 AM
I did some poking around, and the best info I could glean was the TF with the aftermarket out put would be about 20 1/4? That is about 2 3/4 inches longer than a shorty glide. Any idea of how much room there is between the bell housing surface and the pinion ?
Re: Trans question [Re: quickd100] #1806382
04/18/15 05:45 PM
04/18/15 05:45 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
B&M,Fairbanks and others used to make a short tail housing and shaft for dragster/clutchflite trans.
Re: Trans question [Re: quickd100] #1806465
04/18/15 08:42 PM
04/18/15 08:42 PM
nielsville, minn.
Q
Q
nielsville, minn.
Thanks for the replys, I'll find out on Monday. It's very old chassis so I have my doubts that it will pass certification.Dave
Re: Trans question [Re: quickd100] #1806520
04/18/15 10:38 PM
04/18/15 10:38 PM
Might be fun to race at 10.00 though!
Re: Trans question [Re: gregsdart] #1806620
04/19/15 12:41 AM
04/19/15 12:41 AM
nielsville, minn.
Q
Q
nielsville, minn.
Greg, I think I could race my truck at 10.00 and embarrass a bunch of lettered up cars doing it.Dave
Re: Trans question [Re: quickd100] #1806756
04/19/15 10:30 AM
04/19/15 10:30 AM
But you could do it in the FED with a warmed over juice cam 318! My thoughts were it would as reliable as a hammer!
Re: Trans question [Re: quickd100] #1806759
04/19/15 10:31 AM
04/19/15 10:31 AM
