Chrysler 8 3/4 axle end play adjustment #1806526
04/18/15 10:48 PM
04/18/15 10:48 PM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
Is there a way to adjust the axle end play by feel? I have a dial indicator but It doesn't have a clamp on it to put on the brake backing plate. I know it says to tighten the adjuster all the way and then back off 4 notches, what is 4 notches? I figure I wouldn't want much end play, I read online and some guys say they adjust it untill the axles barely have some play, to where they can hear the end play but not see it.
Re: Chrysler 8 3/4 axle end play adjustment [Re: pjc360] #1806545
04/18/15 11:13 PM
04/18/15 11:13 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Four notches in the adjuster in what they are probably referring to. I have done it by feel before but if you never done it before it may be hard for you to tell what is the right amount. Too tight is as bad as not tight enough. Someone here with more experience should be able to lead you thru the process.
Re: Chrysler 8 3/4 axle end play adjustment [Re: mopars4ever] #1806596
04/19/15 12:10 AM
04/19/15 12:10 AM
get a c hair of play (8-10 tho) & you will be fine
Re: Chrysler 8 3/4 axle end play adjustment [Re: pjc360] #1806619
04/19/15 12:38 AM
04/19/15 12:38 AM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
So literally enough end play to where I can hear it moving but can't really see it moving, because if I can see it moving its prob too much right? Or if I do it see moving make sure it's not more then a C hair 😉
Re: Chrysler 8 3/4 axle end play adjustment [Re: pjc360] #1806629
04/19/15 12:53 AM
04/19/15 12:53 AM
N
NITROUSN Offline
NITROUSN  Offline
N
You want to feel it not hear it IMO.
Re: Chrysler 8 3/4 axle end play adjustment [Re: NITROUSN] #1806700
04/19/15 03:12 AM
04/19/15 03:12 AM
iagree Barely feel it, .002 to no more than .010. These are the same type, tapered Timken roller bearings with inner and outer races) and brand as is in all the third members, those have a lot of preload put on them stock so make sure you do NOT have to MUCH end play up
Re: Chrysler 8 3/4 axle end play adjustment [Re: pjc360] #1806927
04/19/15 02:48 PM
04/19/15 02:48 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Factory Service Manual will help too. You do have one right? If not then you can get that info from here:
http://www.mymopar.com/index.php?pid=109
Re: Chrysler 8 3/4 axle end play adjustment [Re: pjc360] #1806993
04/19/15 04:07 PM
04/19/15 04:07 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Chrysler 8 3/4 axle end play adjustment [Re: pjc360] #1807318
04/19/15 11:12 PM
04/19/15 11:12 PM
montana
P
pjc360 Offline OP
pjc360  Offline OP
P
montana
Well I adjusted it untill I could barely move the axle shafts in and out, I would go and check the drivers side axle shaft as well, and I would spin the axles a few revolutions and push and pull on them. I have it set to where they are barely moving in and out. You can feel the axles moving in and out and you can hear it a little of you listen really close.
I think it will be ok. Once I have thA axle installed on the truck I will take it for a drive and listen close for any noises. I think it should be good.
