Re: Chrysler 8 3/4 axle end play adjustment
[Re: pjc360]
#1806545
04/18/15 11:13 PM
04/18/15 11:13 PM
Posts: 13,605 md
mopars4ever
md
Four notches in the adjuster in what they are probably referring to. I have done it by feel before but if you never done it before it may be hard for you to tell what is the right amount. Too tight is as bad as not tight enough. Someone here with more experience should be able to lead you thru the process.
[Re: mopars4ever]
#1806596
04/19/15 12:10 AM
04/19/15 12:10 AM
RapidRobert
get a c hair of play (8-10 tho) & you will be fine
[Re: pjc360]
#1806629
04/19/15 12:53 AM
04/19/15 12:53 AM
Posts: 18,426 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
So literally enough end play to where I can hear it moving but can't really see it moving, because if I can see it moving its prob too much right? Or if I do it see moving make sure it's not more then a C hair 😉 You want to feel it not hear it IMO.
[Re: NITROUSN]
#1806700
04/19/15 03:12 AM
04/19/15 03:12 AM
Posts: 43,257 Bend,OR USA
Cab_Burge
So literally enough end play to where I can hear it moving but can't really see it moving, because if I can see it moving its prob too much right? Or if I do it see moving make sure it's not more then a C hair 😉 You want to feel it not hear it IMO. Barely feel it, .002 to no more than .010. These are the same type, tapered Timken roller bearings with inner and outer races) and brand as is in all the third members, those have a lot of preload put on them stock so make sure you do NOT have to MUCH end play
[Re: pjc360]
#1806993
04/19/15 04:07 PM
04/19/15 04:07 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
