Why the rust? #1806530
04/18/15 10:52 PM
04/18/15 10:52 PM
Tennessee
WyleECoyote Offline OP
Tennessee
So I picked up my engine from Hensley Performance last September. Winter was busy and I didn't get to the garage much, and now I see this?!!!
1. Bolt rust. Understandable, they're iron. What can I use that won't rust - or should I clean these and protect them, with clear?
2. Intake manifold - rust / discoloration. I thought these things were aluminum and would oxidize - but not discolor like this? What is going on?
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: Why the rust? [Re: WyleECoyote] #1806539
04/18/15 11:08 PM
04/18/15 11:08 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I pretty much clear coat everything that might rust now. I even tried some other bare metal coatings with little or no success.
Re: Why the rust? [Re: WyleECoyote] #1806563
04/18/15 11:28 PM
04/18/15 11:28 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Surface contamination on the intake manifold that is now rusting.
Re: Why the rust? [Re: WyleECoyote] #1806581
04/18/15 11:51 PM
04/18/15 11:51 PM
BDW Offline
BDW  Offline
RPM would work on that
Re: Why the rust? [Re: 135sohc] #1806607
04/19/15 12:23 AM
04/19/15 12:23 AM
Tennessee
Tennessee
Surface contamination from what? Its been untouched since new? Mostly....
Wile E. Coyote
Re: Why the rust? [Re: WyleECoyote] #1806608
04/19/15 12:26 AM
04/19/15 12:26 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Mine did the same thing. Not sure what happened. Even the painted power steering box is rusting.
Re: Why the rust? [Re: WyleECoyote] #1806616
04/19/15 12:34 AM
04/19/15 12:34 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Temporary fix, coat with WD 40. Rub a bit of oil on them. Permanent, replace with stainless.
Re: Why the rust? [Re: WyleECoyote] #1806640
04/19/15 01:17 AM
04/19/15 01:17 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
It's called rust, caused by humidity [ moisture ] in your garage. If you had a climate control system in your garage you wouldn't have that problem.
Re: Why the rust? [Re: WyleECoyote] #1806723
04/19/15 06:37 AM
04/19/15 06:37 AM
Groningen, the Netherlands
4doorSatellite Offline
Condensation on your engine caused by a sudden rise in temperature.
This usually happens in early spring when warm moist air meets with your still cold car.
That's my guess anyway.
I have my car in an unheated garage and when temperatures start to rise after winter I regularly check if everything is still dry, engine is the first place to check.
Re: Why the rust? [Re: rowin4] #1806764
04/19/15 10:40 AM
04/19/15 10:40 AM
Slidell, LA
Plum440 Offline
Plum440  Offline
Slidell, LA
What he said.
70 Challenger, 440, 4-speed, pLuM cRaZy
71 VW Super Beetle Convertible, Lemon Yellow
A couple of Jeeps…
Re: Why the rust? [Re: WyleECoyote] #1806778
04/19/15 11:05 AM
04/19/15 11:05 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
bare alum isn't good. the orange on the intake is from iron dust or shavings. alum corrodes fast. if you want the alum look spray with alum paint or paint the parts engine color like mopar did.
Re: Why the rust? [Re: rowin4] #1806794
04/19/15 11:18 AM
04/19/15 11:18 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You forgot the never take it out and drive it part.
Don't be the exception.
Re: Why the rust? [Re: 4doorSatellite] #1806914
04/19/15 02:29 PM
04/19/15 02:29 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
My garage never exceeds 55% RH.
Re: Why the rust? [Re: markz528] #1806938
04/19/15 02:59 PM
04/19/15 02:59 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
That's too damp IMO. I put a dehumidifier in mine to keep it at 35% or less.
